Can not open the example from SDK
2,759 次查看
Hermit
Hi Team,
When I want to open a example project from SDK, I can open it successfully by S32DS,however, I can not open the ".mex" file.It shows that the pins tool was forbidden.
Then, I open the pins tool,but there is no pins that is configured in advance. Also, there is something wrong with the peripheral tools.It just shows that It can not find the drivers in toolchains or IDE and the project can not be compiled.
2,752 次查看
Senlent
Hi@Hermit
please click the Update Code button then you can build the demo successfully!
This demo set the FlexCAN to Loop-Back mode, so it doesn't enable pins tool.
2,749 次查看
Hermit
Hi Senlent,
Thanks.
