I meet a problem as the attached picture, I need some help to solve it, Thanks.
Solved! Go to Solution.
This kind of problem may can be solved by click "update code".
If click "update code" can't solve your problem , i will help you to check it if you can provided the project.
Thank you, I don't know what happend to my project just after a PC restart or some other system issue yesterday and I have done a reactivate to S32DS v3.4 too, However I tried to create a new empty project and migrate my project and it take effect, the problem resolved. Thank you
