Can_43_FLEXCAN and Mcu configuration not loading in EB tresos studio 29.0.0
somto
I'm trying to generate AUTOSAR basic software from CAN example given in SW32K3_RTD_R21-11_4.0.0_P16 (AUTOSAR 4.7.0). However after importing the example to EB tresos studio, all configurations load except Can_43_FLEXCAN and Mcu  configuration.
ERROR says : Invalid XPath-expression for Attribute "EDITABLE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/Platform/ELEMENTS/Platform/GeneralConfiguration/PlatformMulticoreSupport": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR CODE: 1803
VaneB
Hi @somto
Could you try removing the Resource module and then re-adding it?
Also, this error has been discussed in another thread, check it, it might be useful for you.
EB Tresos error when configuring MCAL (RTD) components with Vector DaVinci Configurator Pro
B.R.
VaneB
somto
CAN error : Invalid XPath-expression for Attribute "VISIBLE" of node "/Can_43_FLEXCAN_TS_T40D34M40I0R0/Can/CanConfigSet/CanController/CanClockFromBus": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
somto
This error too : Invalid XPath-expression for Attribute "VISIBLE" of node "/TS_T40D34M40I0R0/Mcu/McuModuleConfiguration/McuModeSettingConf/McuPartitionConfiguration/McuPartition0Config/McuPrtnCofb0UnderMcuControl": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
