CANFD cannot enter receive interrupt
2,260件の閲覧回数
hangli1
Hello, I am using S32K344 to configure canfd, but it is found that it cannot receive can frames during use, so I cannot check what my problem is, hope I can get help
5 返答(返信)
2,242件の閲覧回数
Julián_AragónM
2,229件の閲覧回数
hangli1
Thanks for your reply. I think I have found the cause of the problem
2,232件の閲覧回数
hangli1
Thank you for your reply, but I still have the same problem when I use demo, and the development board still can't observe the CAN data frame from PC through PE. I don't know if there is a problem with my use method or something else, please help me test whether there is any problem with my program, thank you
2,254件の閲覧回数
anderrisen44
Ensure the CAN FD configuration settings match between the sender and receiver, including bitrate, timing, and protocol. Double-check hardware connections and consider debugging with diagnostic tools to pinpoint the issue.
2,252件の閲覧回数
hangli1
Thank you for your reply, but now it can be normally sent to PC. pc receives CAN frames from the development board, but the development board cannot receive messages from PC
