CAN FD and CAN(not Working)
2,876 次查看
GaneshBhagwat
Hello NXP Community,
I'm currently facing an issue with my CAN configuration. I'm using a basic setup for CAN communication, and it only works when I use CAN-FD mode with PEAK CAN Viewer. However, when I try standard Classical CAN (non-FD), I do not receive any response.
I've attached my project for reference. Could someone kindly review it and let me know if there might be any missing configuration or setting that I’ve overlooked?
To summarize:
  • CAN-FD + PEAK CAN Viewer: Working as expected
  • Standard CAN + PEAK CAN Viewer: No response from the board
Any suggestions or guidance would be greatly appreciated.
Thank you in advance!
Ganesh Bhagwat
2,821 次查看
Julián_AragónM
Hi @GaneshBhagwat
Is the PCAN-View tool configured correctly for the mode, baud rate and sampling point?
Is it possible to share what do you see on the bus? (By using a logic analyzer or oscilloscope) just to confirm if the frame is being sent correctly. Also, please elaborate on what "not working" implies; are you able to enter callback upon reception? Is it only transmissions you are having issues with?
I can see in your CANInit function, ID 0x80000 is being set for acceptance, confirm if this is also set in the CAN analyzer.
You can use this community post as guidance for CAN configuration: Example S32K358 FlexCAN TXRX ISR S32DS35 RTD400/500 - NXP Community.
Julián
2,822 次查看
Julián_AragónM
Hi @GaneshBhagwat
Julián
2,761 次查看
GaneshBhagwat
Hi Julián,
Thank you for your response.
I initially suspected a software configuration issue, which is why I posted here. However, it turned out to be a hardware-related problem with the TJA1443 transceiver connection. Due to a floating pin, I was unable to receive or transmit any CAN messages in normal CAN but I don't know why it was working in FD.
After resolving the hardware issue, everything is now working as expected.
Thanks again for taking the time to respond and for pointing me toward the helpful community post.
Ganesh
%3CLINGO-SUB%20id%3D%22lingo-sub-2141012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECAN%20FD%20%E5%92%8C%20CAN%EF%BC%88%E4%B8%8D%E5%B7%A5%E4%BD%9C%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E5%9C%A8%20CAN%20%E9%85%8D%E7%BD%AE%E6%96%B9%E9%9D%A2%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20CAN%20%E9%80%9A%E4%BF%A1%E7%9A%84%E5%9F%BA%E6%9C%AC%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%9C%A8%E4%BD%BF%E7%94%A8%3CSTRONG%3EPEAK%20CAN%20Viewer%3C%2FSTRONG%3E%20%E7%9A%84%3CSTRONG%3ECAN-FD%20%E6%A8%A1%E5%BC%8F%3C%2FSTRONG%3E%E6%97%B6%E6%89%8D%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E6%A0%87%E5%87%86%3CSTRONG%3E%E7%BB%8F%E5%85%B8%20CAN%3C%2FSTRONG%3E%EF%BC%88%E9%9D%9E%20FD%EF%BC%89%E6%97%B6%EF%BC%8C%E5%8D%B4%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E4%BB%BB%E4%BD%95%E5%93%8D%E5%BA%94%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%BB%A5%E4%BE%9B%E5%8F%82%E8%80%83%E3%80%82%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%EF%BC%8C%E5%B9%B6%E5%91%8A%E8%AF%89%E6%88%91%E6%98%AF%E5%90%A6%E6%9C%89%E6%88%91%E5%BF%BD%E7%95%A5%E7%9A%84%E9%85%8D%E7%BD%AE%E6%88%96%E8%AE%BE%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%80%BB%E8%80%8C%E8%A8%80%E4%B9%8B%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3ECAN-FD%20%2B%20PEAK%20CAN%20%E6%9F%A5%E7%9C%8B%E5%99%A8%3C%2FSTRONG%3E%EF%BC%9A%E5%B7%A5%E4%BD%9C%E7%AC%A6%E5%90%88%E9%A2%84%E6%9C%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E6%A0%87%E5%87%86%20CAN%20%2B%20PEAK%20CAN%20%E6%9F%A5%E7%9C%8B%E5%99%A8%3C%2FSTRONG%3E%EF%BC%9A%E6%9D%BF%E6%B2%A1%E6%9C%89%E5%93%8D%E5%BA%94%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%A6%82%E8%83%BD%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E6%88%96%E6%8C%87%E5%AF%BC%EF%BC%8C%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EGanesh%20Bhagwat%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20FD%20and%20CAN(not%20Working)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%83%A1%E5%88%A9%E5%AE%89%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8D%E9%A6%88%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%80%E5%88%9D%E6%80%80%E7%96%91%E6%98%AF%E8%BD%AF%E4%BB%B6%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%EF%BC%8C%E6%89%80%E4%BB%A5%E6%89%8D%E5%9C%A8%E8%BF%99%E9%87%8C%E5%8F%91%E5%B8%96%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E4%BA%8B%E5%AE%9E%E8%AF%81%E6%98%8E%E8%BF%99%E6%98%AF%20TJA1443%20%E6%94%B6%E5%8F%91%E5%99%A8%E8%BF%9E%E6%8E%A5%E7%9A%84%E7%A1%AC%E4%BB%B6%E9%97%AE%E9%A2%98%E3%80%82%E7%94%B1%E4%BA%8E%E6%B5%AE%E7%A9%BA%E5%BC%95%E8%84%9A%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E6%99%AE%E9%80%9A%20CAN%20%E4%B8%AD%E6%8E%A5%E6%94%B6%E6%88%96%E4%BC%A0%E8%BE%93%E4%BB%BB%E4%BD%95%20CAN%20%E6%B6%88%E6%81%AF%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%AE%83%E4%B8%BA%E4%BB%80%E4%B9%88%E8%83%BD%E5%9C%A8%20FD%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%A7%A3%E5%86%B3%E4%BA%86%E7%A1%AC%E4%BB%B6%E9%97%AE%E9%A2%98%E5%90%8E%EF%BC%8C%E7%8E%B0%E5%9C%A8%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8A%BD%E5%87%BA%E6%97%B6%E9%97%B4%E5%9B%9E%E5%A4%8D%E6%88%91%EF%BC%8C%E5%B9%B6%E4%B8%BA%E6%88%91%E6%8C%87%E7%82%B9%E4%BA%86%E6%9C%89%E7%94%A8%E7%9A%84%E7%A4%BE%E5%8C%BA%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EGanesh%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20FD%20and%20CAN(not%20Working)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244803%22%20target%3D%22_blank%22%3E%40GaneshBhagwat%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EPCAN-View%20%E5%B7%A5%E5%85%B7%E7%9A%84%E6%A8%A1%E5%BC%8F%E3%80%81%E6%B3%A2%E7%89%B9%E7%8E%87%E5%92%8C%E9%87%87%E6%A0%B7%E7%82%B9%E9%85%8D%E7%BD%AE%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9F%20%3C%2FP%3E%0A%3CP%3E%E5%8F%AF%E4%BB%A5%E5%88%86%E4%BA%AB%E4%BD%A0%E5%9C%A8%E6%80%BB%E7%BA%BF%E4%B8%8A%E7%9C%8B%E5%88%B0%E7%9A%84%E4%B8%9C%E8%A5%BF%E5%90%97%EF%BC%9F%EF%BC%88%E9%80%9A%E8%BF%87%E4%BD%BF%E7%94%A8%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E5%99%A8%E6%88%96%E7%A4%BA%E6%B3%A2%E5%99%A8%EF%BC%89%E5%8F%AA%E6%98%AF%E4%B8%BA%E4%BA%86%E7%A1%AE%E8%AE%A4%E5%B8%A7%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E5%8F%91%E9%80%81%E3%80%82%E5%8F%A6%E5%A4%96%EF%BC%8C%E8%AF%B7%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%22%E4%B8%8D%E5%B7%A5%E4%BD%9C%22%20%E6%84%8F%E5%91%B3%E7%9D%80%E4%BB%80%E4%B9%88%EF%BC%9B%E6%82%A8%E6%98%AF%E5%90%A6%E8%83%BD%E5%9C%A8%E6%8E%A5%E6%94%B6%E6%97%B6%E8%BE%93%E5%85%A5%E5%9B%9E%E8%B0%83%EF%BC%9F%E5%8F%AA%E6%9C%89%E5%8F%98%E9%80%9F%E5%99%A8%E6%9C%89%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%82%A8%E7%9A%84%20CANInit%20%E5%87%BD%E6%95%B0%E4%B8%AD%EF%BC%8CID%200x80000%20%E8%A2%AB%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%8E%A5%E5%8F%97%EF%BC%8C%E8%AF%B7%E7%A1%AE%E8%AE%A4%20CAN%20%E5%88%86%E6%9E%90%E4%BB%AA%E4%B8%AD%E6%98%AF%E5%90%A6%E4%B9%9F%E8%AE%BE%E7%BD%AE%E4%BA%86%E8%AF%A5%E5%80%BC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%E6%AD%A4%E7%A4%BE%E5%8C%BA%E5%B8%96%E5%AD%90%E7%94%A8%E4%BD%9C%20CAN%20%E9%85%8D%E7%BD%AE%E6%8C%87%E5%8D%97%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K358-FlexCAN-TXRX-ISR-S32DS35-RTD400-500%2Fta-p%2F1981987%22%20target%3D%22_blank%22%3E%E7%A4%BA%E4%BE%8B%20S32K358%20FlexCAN%20TXRX%20ISR%20S32DS35%20RTD400%2F500%20-%20NXP%20%E7%A4%BE%E5%8C%BA%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E
