Ammlib
Ammlib
1,171 次查看
Ayaz
I am trying to use the AMMCLib in my project, but I am missing some information about how to implement the GDFLIB second-order filter.
but I am not getting the values I expect. I am unsure about the purpose of these buffers
fltFiltBufferX
and
fltFiltBufferY
Could you provide some guidance on how to properly use them?
4 回复数
1,146 次查看
_Leo_
Thank you so much for your interest in our products and for using our community.
3.15 GDFLIB_FilterIIR2 section of S32K3XXMCLUG gives more details and code example about it.
You can find such filet in C:\NXP\AMMCLIB\S32K3xx_AMMCLIB_v1.1.39\doc.
Hope it helps you. Please let me know if you have more questions about it.
Have a nice day!
1,081 次查看
Ayaz
i had a look at that document.
I have implemented an IIR filter in my project, which needs to be called periodically. However, the filter only works if I initialize it before each call, which resets the filter. This periodic reset is not acceptable for my design. If I initialize the filter only once at the beginning, it returns NaN values, indicating that the filter is not functioning correctly. Could you please provide an example of how to use the IIR filter effectively for periodic data filtering?
for
GDFLIB_FilterIIR2Init_FLT
and
GDFLIB_FilterIIR2_FLT
969 次查看
_Leo_
Sorry foy delay. I noticed that you have another similar case, so I will follow up on this last one that I mention.
https://community.nxp.com/t5/S32K/Amclib/td-p/2085351
1,028 次查看
Ayaz
I have not received any answer yet
