ADC sampling time per ADC channel
2,483 次查看
Moises
Hello Nxp,
On my project we have different ADC channels (same group) on ADC0. Each of those has a different external circuit (Source impedance, Filter resistance...)
According reference manual:
"ADC TOTAL CONVERSION TIME = Sample Phase Time (set by SMPLTS + 1) + Hold
Phase (1 ADC Cycle) + Compare Phase Time (8-bit Mode = 20 ADC Cycles, 10-bit
Mode = 24 ADC Cycles, 12-bit Mode = 28 ADC Cycles) + Single or First continuous
time adder (5 ADC cycles + 5 bus clock cycles)"
My question is: is it possible to set individual sampling times per ADC channel? (maybe with channel delays in PDB pretriggers)
Thanks in advance
Moises
uC: S32K188
EB Tresos 24.0.1
2,460 次查看
davidtosenovjan
Hi, sample time setting is given by CFG2[SMPLTS] and it is group setting. Possible trigger delays does not lengthen sampling time anyhow. So the answer is no, it cannot be configured per channel.
2,453 次查看
Moises
Thanks for the fast reply;
could be done by creating different groups?
2,420 次查看
davidtosenovjan
I am sorry, I haven't meant group in this meaning. I just meant all channels.
