AB_SWAP Linker file for S32K344
IAussman
Hi NXP community,
As I'm working with HSE module, I would like to know if NXP provides S32K344's linker file samples for AB_swap configuration.
Or should we modify the original manually?
Thank you in advance for your support.
lukaszadrapa
Hi Aussman,
we do not provide such tool. It's possible to use tools like https://www.openssl.org/
Lukas
lukaszadrapa
Hi Aussman,
I don't think we provide such sample linker file. You can check linker files in HSE_DEMOAPP but that's probably not the best example.
Customers usually create their own linker files based on their needs, so the best way is probably to modify original linker file as needed.
Lukas
IAussman
Hi Lukas,
Thank you for your rapid response. In complement to that, I would like to know if there is any tool compatible with S32K344 HSE that allows to sign a firmware and generate a signature.
Thus, letting HSE only do the signature verification.
Thanks.
Aussman
lukaszadrapa
Hi Aussman,
Lukas
IAussman
Right, thank you.
Aussman
