通过PE进入Debug,界面就会卡死
通过PE进入Debug,界面就会卡死
陆小龙
从创建Project到Debug Configurations中把C/C++ Application(elf文件)导入后,点击Debug,跳转到Debug界面就会卡死,如附件所示。我的目的是想通过PE(Real Time Expressions)查看一些数据。
Crush·Wilson
Robin_Shen
Hi 陆小龙,
As you described the method:
1. Create a project for that device in the IDE
2. In the Debug Configurations, use your .elf file instead
After click Debug, you should be able to see data in Real Time Expressions view.
Robin
