编译时Problems报错
编译时Problems报错
JXLIN
描述
错误(81 项)
Ld error:./Generated_Code/clockMan1.o 使用 VFP 寄存器参数,BlancAppS32k142Boot.elf 不使用 Ld 错误:./Generated_Code/Cpu.o 使用 VFP 寄存器参数,BlancAppS32k142Boot.elf 不
使用 Ld 错误:./Generated_Code/dmaController1.o 使用 VFP 寄存器参数,BlancAppS32k142Boot.elf 不使用 Ld 错误:./Generated_Code/Flash1.o 使用 VFP 寄存器参数,BlancAppS32k142Boot.elf 不 Ld 错误:./Generated_Code/lpit1.o 使用 VFP 寄存器参数,BlancAppS32k142Boot.elf 不 Ld 错误:./Generated_Code/pin_mux.o 使用 VFP 寄存器参数,BlancAppS32k142Boot.elf 不 Ld 错误:./Generated_Code/watchdog1.o 使用 VFP 寄存器参数,BlancAppS32k142Boot.elf 不
Ld 错误:./SDK/platform/devices/S32K146/startup/system_S32K146.o 使用 VFP 寄存器参数,BlancAppS32k142Boot.elf 不
Julián_AragónM
Hi @JXLIN,
Most likely, the configured compiler uses hard-float ABI. The error message indicates that at least part of your system is using soft-float ABI.
Please check that your compilation and toolchain options are correct or at least are consistent:
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2150390%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EProblems%20at%20compile%20time%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150390%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EDescription%20%3CBR%20%2F%3EError%20(81%20items)%20%3CBR%20%2F%3ELd%20error%3A%20.%20%2FGenerated_Code%2FclockMan1.o%20Using%20VFP%20register%20parameters%2C%20BlancAppS32k142Boot.elf%20does%20not%20use%20Ld%20Error%3A%20.%20%2FGenerated_Code%2FCpu.o%20Using%20VFP%20register%20parameter%2C%20BlancAppS32k142Boot.el%20not%20%3CBR%20%2F%3EUsing%20Ld%20Error%3A%20.%20%2FGenerated_Code%2FdmaController1.o%20Using%20VFP%20register%20parameter%2C%20BlancAppS32k142Boot.elf%20not%20Ld%20error%3A%20.%20%2FGenerated_Code%2FFlash1.o%20Using%20VFP%20register%20parameter%2C%20BlancAppS32k142Boot.elf%20not%20Ld%20Error%3A%20.%20%2FGenerated_Code%2Flpit1.o%20Using%20VFP%20register%20parameter%2C%20BlancAppS32k142Boot.elf%20not%20Ld%20Error%3A%20.%20%2FGenerated_Code%2Fpin_mux.o%20Use%20VFP%20register%20parameter%2C%20BlancAppS32k142Boot.elf%20not%20Ld%20Error%3A%20.%20%2FGenerated_Code%2Fwatchdog1.o%20Using%20the%20VFP%20register%20parameter%2C%20BlancAppS32k142Boot.elf%20does%20not%20%3CBR%20%2F%3ELd%20error%3A%20.%20%2FSDK%2Fplatform%2Fdevices%2FS32K146%2Fstartup%2Fsystem_S32K146.o%20Using%20the%20VFP%20register%20parameter%2C%20BlancAppS32k142Boot.elf%20does%20not%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%E7%BC%96%E8%AF%91%E6%97%B6Problems%E6%8A%A5%E9%94%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247881%22%20target%3D%22_blank%22%3E%40JXLIN%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMost%20likely%2C%20the%20configured%20compiler%20uses%26nbsp%3B%3C%2FSPAN%3E%3CEM%3Ehard-float%3C%2FEM%3E%3CSPAN%3E%26nbsp%3BABI.%26nbsp%3BThe%20error%20message%20indicates%20that%20at%20least%20part%20of%20your%20system%20is%20using%26nbsp%3B%3CEM%3Esoft-float%3C%2FEM%3E%26nbsp%3BABI.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPlease%20check%20that%20your%20compilation%20and%20toolchain%20options%20are%20correct%20or%20at%20least%20are%20consistent%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-IDE%2Fquot-MyProj-axf-uses-VFP-register-arguments-MyLib-libmy-a-my%2Fm-p%2F1628673%22%20target%3D%22_blank%22%3ESolved%3A%20Re%3A%20%22MyProj.axf%20uses%20VFP%20register%20arguments%2C%20MyLib%2Flibmy.a(my_file.o)%20does%20not%22%3B%20both%20set%20-%20NXP%20Community%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FKinetis-Design-Studio%2FError-VFP-register%2Fm-p%2F426794%22%20target%3D%22_blank%22%3EError%3A%20VFP%20register%20-%20NXP%20Community%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E
