关于S32K312 DCMDEB寄存器中APPDBG_STAT_SOC位的具体意义
teddywang
hi sir
danielmartynek
Hello @teddywang,
As you can see in the RM, Figure 138. Recovery mode sequence. the bit is set when a successful debug authorization sequence has completed and JTAG is enabled on the application core.
More information about the authorization in Section 79.11 Debug across device LifeCycles.
