Example S32K344 PIT BTCU ADC DMA DS3.4 RTD100
* The purpose of this demo application is to present a usage of the ADC_SAR and
* BCTU IP Driver for the S32K3xx MCU.
* The example uses the PIT0 trigger to trigger BCTU conversion list. Five standard
* ADC channels are selected to be converted.
* Converted result from BCTU data register are moved by DMA into result array.
* This result array should be placed into no cacheable area if data cache is enabled.
* ADC channel S10 is connected to board's potentiometer, and converted value is
* used to dim board's LED.
* Test HW: S32K3X4EVB-Q172
* MCU: S32K344
* Compiler: S32DS3.4
* SDK release: RTD 1.0.0
* Debugger: Lauterbach
* Target: internal_FLASH
Comments
How Can I get permission to download the attachment
%3CLINGO-SUB%20id%3D%22lingo-sub-1435324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20S32K344%20PIT%20BTCU%20ADC%20DMA%20DS3.4%20RTD100%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1435324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CPRE%3E*******************************************************************************%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20The%20purpose%20of%20this%20demo%20application%20is%20to%20present%20a%20usage%20of%20the%20ADC_SAR%20and%20%3CBR%20%2F%3E*%20BCTU%20IP%20Driver%20for%20the%20S32K3xx%20MCU.%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20The%20example%20uses%20the%20PIT0%20trigger%20to%20trigger%20BCTU%20conversion%20list.%20Five%20standard%20%3CBR%20%2F%3E*%20ADC%20channels%20are%20selected%20to%20be%20converted.%3CBR%20%2F%3E*%20Converted%20result%20from%20BCTU%20data%20register%20are%20moved%20by%20DMA%20into%20result%20array.%3CBR%20%2F%3E*%20This%20result%20array%20should%20be%20placed%20into%20no%20cacheable%20area%20if%20data%20cache%20is%20enabled.%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20ADC%20channel%20S10%20is%20connected%20to%20board's%20potentiometer%2C%20and%20converted%20value%20is%20%3CBR%20%2F%3E*%20used%20to%20dim%20board's%20LED.%3CBR%20%2F%3E*%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%20S32K3X4EVB-Q172%3CBR%20%2F%3E*%20MCU%3A%20S32K344%3CBR%20%2F%3E*%20Compiler%3A%20S32DS3.4%3CBR%20%2F%3E*%20SDK%20release%3A%20RTD%201.0.0%3CBR%20%2F%3E*%20Debugger%3A%20Lauterbach%3CBR%20%2F%3E*%20Target%3A%20internal_FLASH%3CBR%20%2F%3E********************************************************************************%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1675936%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20S32K344%20PIT%20BTCU%20ADC%20DMA%20DS3.4%20RTD100%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1675936%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHow%20Can%20I%20get%20permission%20to%20download%20the%20attachment%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎11-14-2022 04:04 AM
Updated by:
