Example S32K144 FlexIO Idle Detection S32DS2.2
* Detailed Description:
* FlexIO module is configured for UART RX and TX function.
* Timer 0 and Shifter 0 is used for UART TX function.
* Timer 1 and Shifter 1 is used for UART RX function.
* Timer 2 is used for idle detection.
* Baud rate = 115200
* HW connection: PTA0 - TX, PTA1 - RX, PTA7 is used to signalize idle detection.
* Connect PTA0 and PTA1 to create external loopback for this test.
* Test HW: S32K144EVB
* MCU: FS32K144HAMLL 0N57U
* Fsys: 80MHz
* Debugger: Lauterbach Trace32
* Target: internal_FLASH
%3CLINGO-SUB%20id%3D%22lingo-sub-1368670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20S32K144%20FlexIO%20Idle%20Detection%20S32DS2.2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1368670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20FlexIO%20module%20is%20configured%20for%20UART%20RX%20and%20TX%20function.%3CBR%20%2F%3E*%20Timer%200%20and%20Shifter%200%20is%20used%20for%20UART%20TX%20function.%3CBR%20%2F%3E*%20Timer%201%20and%20Shifter%201%20is%20used%20for%20UART%20RX%20function.%3CBR%20%2F%3E*%20Timer%202%20is%20used%20for%20idle%20detection.%3CBR%20%2F%3E*%20Baud%20rate%20%3D%20115200%3CBR%20%2F%3E*%20HW%20connection%3A%20PTA0%20-%20TX%2C%20PTA1%20-%20RX%2C%20PTA7%20is%20used%20to%20signalize%20idle%20detection.%3CBR%20%2F%3E*%20Connect%20PTA0%20and%20PTA1%20to%20create%20external%20loopback%20for%20this%20test.%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%20S32K144EVB%3CBR%20%2F%3E*%20MCU%3A%20FS32K144HAMLL%200N57U%3CBR%20%2F%3E*%20Fsys%3A%2080MHz%3CBR%20%2F%3E*%20Debugger%3A%20Lauterbach%20Trace32%3CBR%20%2F%3E*%20Target%3A%20internal_FLASH%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎11-09-2021 09:02 AM
Updated by:
