which hse firmware works for s32g3 to build bootloader project ?
fengxianeric
Buddy,  I am building bootloader project and do configuration, I see 2 version hse fw files, could you tell me which one works for this ?
Daniel-Aguirre
Thanks for your feedback. S32G399A is one section of the part number, the section you want to know is the Kx (11-12 character, as mentioned under the S32G3 datasheet image shown before).
Depending on which Kx is you chip, is the revision you should use (also mentioned before).
Please, let us know.
Daniel-Aguirre
Depends on which G3 chip you have installed on your board. The following is told under the Release Notes of the HSE:
This is related to the "Kx" revision of you chip, as seen under the S32G3 datasheet:
K0 should be rev 1.0 while K1 should be rev 1.1.
fengxianeric
I am working for s32g399A.
Daniel-Aguirre
