use HSE do message authentication and asymmetric encryption and decryption on S32G
eone
Hi NXP,
i am using https://github.com/nxp-auto-linux/pkcs11-hse to build hse-encrypto.c on s32g274ardb2 platform,Its provide a AES key generate and crypto example, the program working successful, when i try modify some parameters in the file:such as HSE_KF_USAGE_ENCRYPT、HSE_CIPHER_ALGO_AES、HSE_CIPHER_BLOCK_MODE_CBC to test HMAC and asymmetric encryption and decryption
the program failed and prompt "hse: service response 0x55A5A399 on channel 1", What is the reason for this and How should I solve this problem?
can you provide me with examples of message authentication and asymmetric encryption and decryption for my reference, thanks!
MayanksPatel
Hi @eone,
Can you please share in detail what values of parameters you changed?
Also, Share the HSE Firmware version which you are using.
Mayank s Patel
