s32g2 gpio pinout is9141
ilir
hi maybe someone can shed light in to this
iam making a connection as iso9141 with the s32g2 and e-l9637d013tr but i would like a suggestion as what for gpio to use thank you
Daniel-Aguirre
We might not understand the request you are posting. We see that "e-l9637d013tr" is an ST part, but do not understand what is the connection that you are trying to do.
If this is related to the connections that are specific to the ST part, help us contacting ST support team, for them to provide comments on your request.
As for S32G, we do not see anything on regards of the ISO9141 you are telling. We do apologize.
Please, let us know.
ilir
hi daniel thats to do obd2 tool for cars usually it goes thruw uart or something like that
iso9141 has a kline and an L line wich is used in automotive industry maybe that can clear out something
Daniel-Aguirre
If it goes through UART, you should be able to connect it to the UART available pins. Just, confirm the voltage compatibility between the S32G and the ST part.
