s32g2 bitbake failure with perl
1,568 次查看
Juin0223
I followed the S32G2_LinuxBSP_35.0_User_Manual.pdf to build the fsl-image-auto for s32g274ardb2.
It failed during build/install the perl package:
~/fsl-auto-yocto-bsp/build_s32g274ardb2$ bitbake -c cleanall perl
Loading cache: 100% |##########################################################################################################################################| Time: 0:00:01
Loaded 4898 entries from dependency cache.
Parsing recipes: 100% |########################################################################################################################################| Time: 0:00:01
Parsing of 3301 .bb files complete (3300 cached, 1 parsed). 4901 targets, 265 skipped, 6 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION           = "1.48.0"
BUILD_SYS            = "x86_64-linux"
NATIVELSBSTRING      = "universal"
TARGET_SYS           = "aarch64-fsl-linux"
MACHINE              = "s32g274ardb2"
DISTRO               = "fsl-auto"
DISTRO_VERSION       = "35.0"
TUNE_FEATURES        = "aarch64 armv8a crc cortexa53 crypto"
TARGET_FPU           = ""
meta
meta-poky
meta-yocto-bsp       = "HEAD:6a751048e50c00261d99c2d8d69534f7a8da38a9"
meta-oe
meta-multimedia
meta-python          = "HEAD:f3f7a5f1a4713f145107bb043e0d14cb3a51c62f"
meta-python2         = "HEAD:3fae17aece0e6d82f56965fe501bf7080c671df8"
meta-networking
meta-gnome
meta-filesystems
meta-webserver
meta-perl
meta-xfce            = "HEAD:f3f7a5f1a4713f145107bb043e0d14cb3a51c62f"
meta-virtualization  = "HEAD:fa093228c02c4a42da1f9abb77c4c57d70d5a212"
meta-optee           = "HEAD:fb96032b38e3064290ab0891238c92d47a45f151"
meta-security        = "HEAD:3daf99fd138b0eebe864bbe1b9c71241d97c4512"
meta-freescale       = "HEAD:41d4f625c6db7a778f0f9a735c2cb48e023bc49b"
meta-alb             = "HEAD:80cfe1f8d78da5bc46d646942047cd5ec13c3e11"
Initialising tasks: 100% |#####################################################################################################################################| Time: 0:00:00
Sstate summary: Wanted 0 Found 0 Missed 0 Current 0 (0% match, 0% complete)
NOTE: No setscene tasks
NOTE: Executing Tasks
NOTE: Tasks Summary: Attempted 3 tasks of which 0 didn't need to be rerun and all succeeded.
~/fsl-auto-yocto-bsp/build_s32g274ardb2$ bitbake perl
Parsing recipes: 100% |########################################################################################################################################| Time: 0:00:00
DISTRO               = "fsl-auto"
TARGET_FPU           = ""
meta
meta-poky
meta-oe
meta-multimedia
meta-networking
meta-gnome
meta-filesystems
meta-webserver
meta-perl
Checking sstate mirror object availability: 100% |#############################################################################################################| Time: 0:00:00
Sstate summary: Wanted 172 Found 0 Missed 172 Current 134 (0% match, 43% complete)
ERROR: perl-native-5.32.0-r0 do_install: oe_runmake failed
ERROR: perl-native-5.32.0-r0 do_install: Execution of '/home/debing/fsl-auto-yocto-bsp/build_s32g274ardb2/tmp/work/x86_64-linux/perl-native/5.32.0-r0/temp/run.do_install.22667' failed with exit code 1:
make install.perl
make[1]: Entering directory '/home/debing/fsl-auto-yocto-bsp/build_s32g274ardb2/tmp/work/x86_64-linux/perl-native/5.32.0-r0/perl-5.32.0'
./miniperl_top installperl --destdir=/home/debing/fsl-auto-yocto-bsp/build_s32g274ardb2/tmp/work/x86_64-linux/perl-native/5.32.0-r0/image
perl isn't executable!
Makefile:424: recipe for target 'install.perl' failed
make[1]: *** [install.perl] Error 2
make[1]: Leaving directory '/home/debing/fsl-auto-yocto-bsp/build_s32g274ardb2/tmp/work/x86_64-linux/perl-native/5.32.0-r0/perl-5.32.0'
Makefile:420: recipe for target 'install' failed
make: *** [install] Error 2
WARNING: exit code 1 from a shell command.
ERROR: Logfile of failure stored in: /home/debing/fsl-auto-yocto-bsp/build_s32g274ardb2/tmp/work/x86_64-linux/perl-native/5.32.0-r0/temp/log.do_install.22667
Log data follows:
| DEBUG: Executing shell function do_install
| NOTE: make -j 6 DESTDIR=/home/debing/fsl-auto-yocto-bsp/build_s32g274ardb2/tmp/work/x86_64-linux/perl-native/5.32.0-r0/image install
| make install.perl
| ERROR: oe_runmake failed
| ERROR: Execution of '/home/debing/fsl-auto-yocto-bsp/build_s32g274ardb2/tmp/work/x86_64-linux/perl-native/5.32.0-r0/temp/run.do_install.22667' failed with exit code 1:
| make install.perl
ERROR: Task (virtual:native:/home/debing/fsl-auto-yocto-bsp/sources/poky/meta/recipes-devtools/perl/perl_5.32.0.bb:do_install) failed with exit code '1'
NOTE: Tasks Summary: Attempted 594 tasks of which 584 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
1,445 次查看
chenyin_h
Hello, @Juin0223
Glad to know it, you are welcome.
Best Regards
Chenyin
1,449 次查看
Juin0223
Thanks, @chenyin_h . I rerun the command to rebuild the BSP. It finally worked.
1,535 次查看
chenyin_h
Hello, @Juin0223
Thanks for the question.
I have tested it on my own BSP35 setup carefully with the commands listed in your log, but no issues from my side.
From the “Linux BSP 35.0 User Manual for S32G2 platforms”, all the steps described in the user manual have been run and validated on Ubuntu-18.04 LTS, as a result, we recommend to install  Ubuntu-18.04 LTS for building the BSP.
Furthermore, don’t forget to run the following script before the build.
./sources/meta-alb/scripts/host-prepare.sh
Let me know if it helps
Best Regards
Chenyin
