arm-trusted-firmware not build successfully
Jeyaseelan_Kirubaharan
Hi All,
I am trying to build the arm-trusted-firmware for S32G. But the build is not successful
git clone https://github.com/nxp-auto-linux/arm-trusted-firmware.git
cd arm-trusted-firmware && git checkout release/bsp37.0-2.5
make CROSS_COMPILE=aarch64-none-linux-gnu- ARCH=aarch64 PLAT=s32g3xxaevb3 \
BL33=../u-boot/u-boot-nodtb.bin S32_HAS_HV=1 S32_USE_LINFLEX_IN_BL31=1 LOG_LEVEL=40
Getting the below error
user:~/Audi_ADAS/arm-trusted-firmware$ make CROSS_COMPILE=../compiler/arm-gnu-toolchain-14.3.rel1-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu- ARCH=aarch64 PLAT=s32g3xxaevb3 BL33=../u-boot/u-boot-nodtb.bin S32_HAS_HV=1 S32_USE_LINFLEX_IN_BL31=1 LOG_LEVEL=40
HOSTCC fiptool.c
HOSTCC tbbr_config.c
HOSTLD fiptool
Built fiptool successfully
FIP /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/dummy_fip
MKIMAGE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/dummy_fip.s32
MKIMAGE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/ivt_location
MKIMAGE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/fip_offset
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/fip_mmc_offset_flag
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/fip_qspi_offset_flag
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/fip_mem_offset_flag
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/fip_hdr_size
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/dtb_size
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/boot_info.c
CC /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/boot_info.c
LD /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/bl31SRAM/bl31SRAM.elf
../compiler/arm-gnu-toolchain-14.3.rel1-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu-ld: warning: /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/bl31SRAM/bl31SRAM.elf has a LOAD segment with RWX permissions
make: *** [plat/nxp/s32/s32g/bl31_sram/bl31_sram.mk:28: /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/bl31SRAM/bl31SRAM.elf] Error 1
It will be useful if someone provide the suggestion to get over this error.
With regards,
Jeyaseelan
alejandro_e
Hello @Jeyaseelan_Kirubaharan,
Thanks for reaching out to us and thanks for the detailed description of your problem. Checking your logs I see you are using  arm-gnu-toolchain-14.3.rel1-x86_64-aarch64-none-linux-gnu while the BSP37 user manual indicates to use arm-gnu-toolchain-11.3.rel1-x86_64-aarch64-none-linux-gnu, I verified myself and I was able to compile ATF + u-boot without problems.
Can you try using the recommended ARM GCC version and let me know if the behavior is different?
Thanks in advance
Please find attached the complete log.
alejandro_e
Thanks in advance
Hi Alejandro,
As mentioned from you , after changing the compiler version we can able to build the ATF successfully.
Thanks for the support..
With regards,
Jeyaseelan
alejandro_e
I'm glad to know you were able to solve your problem! If possible please select my previous answer as an accepted solution.
Thanks in advance
%3CLINGO-SUB%20id%3D%22lingo-sub-2143610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Earm-trusted-firmware%20not%20build%20successfully%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20All%2C%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20build%20the%20arm-trusted-firmware%20for%20S32G.%20But%20the%20build%20is%20not%20successful%3C%2FP%3E%3CP%3Egit%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Farm-trusted-firmware.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Farm-trusted-firmware.git%3C%2FA%3E%3CBR%20%2F%3Ecd%20arm-trusted-firmware%20%26amp%3B%26amp%3B%20git%20checkout%20release%2F%3CSTRONG%3Ebsp37.0-2.5%3C%2FSTRONG%3E%26nbsp%3B%3C%2FP%3E%3CP%3Emake%20CROSS_COMPILE%3Daarch64-none-linux-gnu-%20ARCH%3Daarch64%20PLAT%3Ds32g3xxaevb3%20%5C%3CBR%20%2F%3EBL33%3D..%2Fu-boot%2Fu-boot-nodtb.bin%20S32_HAS_HV%3D1%20S32_USE_LINFLEX_IN_BL31%3D1%20LOG_LEVEL%3D40%3C%2FP%3E%3CP%3EGetting%20the%20below%20error%3C%2FP%3E%3CP%3Euser%3A~%2FAudi_ADAS%2Farm-trusted-firmware%24%20make%20CROSS_COMPILE%3D..%2Fcompiler%2Farm-gnu-toolchain-14.3.rel1-x86_64-aarch64-none-linux-gnu%2Fbin%2Faarch64-none-linux-gnu-%20ARCH%3Daarch64%20PLAT%3Ds32g3xxaevb3%20BL33%3D..%2Fu-boot%2Fu-boot-nodtb.bin%20S32_HAS_HV%3D1%20S32_USE_LINFLEX_IN_BL31%3D1%20LOG_LEVEL%3D40%3CBR%20%2F%3EHOSTCC%20fiptool.c%3CBR%20%2F%3EHOSTCC%20tbbr_config.c%3CBR%20%2F%3EHOSTLD%20fiptool%3C%2FP%3E%3CP%3EBuilt%20fiptool%20successfully%3C%2FP%3E%3CP%3EFIP%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fdummy_fip%3CBR%20%2F%3EMKIMAGE%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fdummy_fip.s32%3CBR%20%2F%3EMKIMAGE%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fivt_location%3CBR%20%2F%3EMKIMAGE%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Ffip_offset%3CBR%20%2F%3ECREATE%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Ffip_mmc_offset_flag%3CBR%20%2F%3ECREATE%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Ffip_qspi_offset_flag%3CBR%20%2F%3ECREATE%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Ffip_mem_offset_flag%3CBR%20%2F%3ECREATE%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Ffip_hdr_size%3CBR%20%2F%3ECREATE%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fdtb_size%3CBR%20%2F%3ECREATE%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fboot_info.c%3CBR%20%2F%3ECC%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fboot_info.c%3CBR%20%2F%3ECC%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fboot_info.c%3CBR%20%2F%3ELD%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fbl31SRAM%2Fbl31SRAM.elf%3CBR%20%2F%3E..%2Fcompiler%2Farm-gnu-toolchain-14.3.rel1-x86_64-aarch64-none-linux-gnu%2Fbin%2Faarch64-none-linux-gnu-ld%3A%20warning%3A%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fbl31SRAM%2Fbl31SRAM.elf%20has%20a%20LOAD%20segment%20with%20RWX%20permissions%3CBR%20%2F%3Emake%3A%20***%20%5Bplat%2Fnxp%2Fs32%2Fs32g%2Fbl31_sram%2Fbl31_sram.mk%3A28%3A%20%2Fhome%2Fuser%2FAudi_ADAS%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fbl31SRAM%2Fbl31SRAM.elf%5D%20Error%201%3C%2FP%3E%3CP%3EIt%20will%20be%20useful%20if%20someone%20provide%20the%20suggestion%20to%20get%20over%20this%20error.%3C%2FP%3E%3CP%3EWith%20regards%2C%3C%2FP%3E%3CP%3EJeyaseelan%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-trusted-firmware%20not%20build%20successfully%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202483%22%20target%3D%22_blank%22%3E%40Jeyaseelan_Kirubaharan%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI'm%20glad%20to%20know%20you%20were%20able%20to%20solve%20your%20problem!%20If%20possible%20please%20select%20my%20previous%20answer%20as%20an%20accepted%20solution.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20in%20advance%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-trusted-firmware%20not%20build%20successfully%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Alejandro%2C%3C%2FP%3E%3CP%3EAs%20mentioned%20from%20you%20%2C%20after%20changing%20the%20compiler%20version%20we%20can%20able%20to%20build%20the%20ATF%20successfully.%3C%2FP%3E%3CP%3EThanks%20for%20the%20support..%3C%2FP%3E%3CP%3EWith%20regards%2C%3C%2FP%3E%3CP%3EJeyaseelan%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-trusted-firmware%20not%20build%20successfully%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202483%22%20target%3D%22_blank%22%3E%40Jeyaseelan_Kirubaharan%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20reaching%20out%20to%20us%20and%20thanks%20for%20the%20detailed%20description%20of%20your%20problem.%20Checking%20your%20logs%20I%20see%20you%20are%20using%26nbsp%3B%26nbsp%3B%3CEM%3Earm-gnu-toolchain-%3CSTRONG%3E14.3.rel1%3C%2FSTRONG%3E-x86_64-aarch64-none-linux-gnu%26nbsp%3B%3C%2FEM%3Ewhile%20the%20BSP37%20user%20manual%20indicates%20to%20use%26nbsp%3B%3CEM%3Earm-gnu-toolchain-%3CSTRONG%3E11.3.rel1%3C%2FSTRONG%3E-x86_64-aarch64-none-linux-gnu%3C%2FEM%3E%2C%26nbsp%3BI%20verified%20myself%20and%20I%20was%20able%20to%20compile%20ATF%20%2B%20u-boot%20without%20problems.%3C%2FP%3E%0A%3CP%3ECan%20you%20try%20using%20the%20recommended%20ARM%20GCC%20version%20and%20let%20me%20know%20if%20the%20behavior%20is%20different%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20in%20advance%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-trusted-firmware%20not%20build%20successfully%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20find%20attached%20the%20complete%20log.%3C%2FP%3E%3C%2FLINGO-BODY%3E
