Hi There,
To add an RTD path to your project in Tresos, you can follow these steps:
- Open your Tresos project.
- Go to the 'Project Explorer' view, and right-click on your project name.
- Select 'Properties' from the context menu.
- In the 'Properties' window, navigate to the 'Tresos' category and click on 'Paths'.
- Under the 'RTD Paths' section, click on the 'Add...' button.
- Browse to the location of your RTD file and select it.
- Click 'OK' to close the 'Properties' window and save your changes.
By following these steps, you should have successfully added the RTD path to your Tresos project. If you encounter any issues or need further assistance, please refer to the Automotive Software and Tools Knowledge Base for more information and resources.
