bsp 40.0. yes rdb3 thats right.Yes built bsp with yocto.Thank you for the prompt reply
I am using BSP 40 version. Yes RDB3 thats correct. Yes built BSP with yocto.
Thanks for your feedback. Overall, we don't seem to find any problems under BSP40.0 regarding IPCF.
Are you able to use the NXP pre-built images to confirm if the behavior can be replicated? If not, then this might be related to the overall build, rather than the BSP40.0 itself.
Please, let us know.
Can you let us know which BSP version are you working with? We see that you are using an RDB3, is this correct?
Also, did you build your BSP with yocto? Or are you using the pre-built images provided by NXP (in a *tgz file)?
