Hi Team:
https://community.nxp.com/t5/NXP-Designs-Knowledge-Base/S32G-ADD-GDFLASH-SUPPORT/ta-p/1763551
According to this document, I support gd25lx256e nor flash in the BSP38 package, when using mtd_debug to read nor flash report memory error, I want to consult this document support BSP38 use?
When reading nor flash beyond 128 bytes, the memory will be abnormal.
What configuration do I need to pay attention to when using?
The read protocol I am using is STR_1_1_8, the clock frequency is 133MHz
