hello, nxp,
according to MCAL configuration of SPI for S32G399, check the picture bellow:
Does the MCAL support SPI slave mode ?
Do NXP have some example about how to demo the spi mode of MCAL ?
The SPI ports on the S32Gx are capable of being Master or Slave. By modifying the MSTR bit the interface is able to change between a Master Node and a Slave Node.
At this moment, only an SPI master example is provided inside the RTD SDK for S32G2/3, we de apologize. What functionality do you need to have in this example? Just changing the master node to a slave node?
Please, let us know if there is anything else we can help you with.
