S32g274用BSP35.0在板子上启动之后提示初始化XPCS失败
sdx111
我在使用自己做的板子时候,从uboot启动时候提示关于XPCS的错误,相关错误提示在附件中,想请教下这个错误可能和什么有关系?
Daniel-Aguirre
We understood that you are having problems with XPCS starting up under your custom board, is this correct?
If so, this might be related to the hardware design or the SerDes configuration.
For the error logs you are showing, we might understand that it is related to the hardware itself. Can you confirm if you see these messages under an NXP reference board (that is, if the configuration is feasible).
Please, let us know.
