S32G399A LinuxBSP_42.0 Boot DDR ERROR
jh_park_nt
We have a GoldBox 3 Vehicle Networking Development Platform, but we are unable to make it boot.
Boot log full ouput :
NOTICE: Reset status: Power-On Reset
ERROR: Failed to configure the DDR subsystem
PANIC at PC : 0x000000000000003f
We found a similar question on the following link:
https://community.nxp.com/t5/S32G/S32G3-VPN-Linux-BSP-Won-t-Boot-DDR-Error/m-p/1998154#M11789
So We tried using Serial Boot with S32 Design Studio 3.5, and we got the following log:
D:\NXP_Platform\eclipse>D:\NXP_Platform\S32DS\build_tools\msys32\mingw32\bin\python2 D:\NXP_Platform\eclipse\mcu_data\processors\S32G399A\PlatformSDK_S32XX_4_0_0\scripts\ddrv\scripts\s.py -l DEBUG -parentPID 8464 "C:/Users/jhpar/AppData/Local/Temp/mem_validation/connect.json" "C:/Users/jhpar/AppData/Local/Temp/mem_validation/test.json" "C:/Users/jhpar/AppData/Local/Temp/mem_validation/phy.json"
DEBUG:test:Initializing test
INFO:test:Using binary D:/NXP_Platform/eclipse/mcu_data/processors/S32G399A/PlatformSDK_S32XX_4_0_0/scripts/ddrv/binaries/S32G3_M7_A53.bin
DEBUG:backend:Executing: set remotetimeout 60000
DEBUG:backend:Executing: set debug remote 0
DEBUG:backend:Executing: set interactive-mode off
DEBUG:backend:Executing: set pagination off
DEBUG:backend:Executing: set print repeats 0
DEBUG:backend:Executing: disconnect
DEBUG:utils.serial_lib:App path D:/NXP_Platform/eclipse/mcu_data/processors/S32G399A/PlatformSDK_S32XX_4_0_0/scripts/ddrv/binaries/S32G3_M7_A53.bin
DEBUG:utils.serial_lib:establishing bootrom connection
DEBUG:utils.serial_lib:HEADER :
['0xd8', '0x0', '0x0', '0x60', '0x0', '0x0', '0x30', '0x34', '0x0', '0x0', '0x30', '0x34', '0x50', '0x31', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0']
INFO:utils.serial_lib:Writing firmware.
DEBUG:utils.serial_lib:12624
DEBUG:utils.serial_lib:1 / 4
DEBUG:utils.serial_lib:2 / 4
DEBUG:utils.serial_lib:3 / 4
DEBUG:utils.serial_lib:4 / 4
INFO:utils.serial_lib:Writing firmware completed.
DEBUG:utils.serial_lib:establishing master connection
DEBUG:utils.serial_lib:Requested ACK
DEBUG:utils.serial_lib:Received ACK
DEBUG:gdbcommands.commands:----------------------------------
DEBUG:gdbcommands.commands:C:\Users\jhpar\AppData\Local\Temp\mem_validation\phy.json
INFO:gdbcommands.commands:Preparing DDR training data
DEBUG:utils.serial_lib:Read value FEDC8855
DEBUG:backend:[ SerialLib ] Writing file to memory
DEBUG:backend:> From File: D:/NXP_Platform/eclipse/mcu_data/processors/S32G399A/PlatformSDK_S32XX_4_0_0/scripts/ddrv/binaries/phy/g3_phy.bin
DEBUG:backend:> To address: 0x34000000
DEBUG:backend:> From File: C:\Users\jhpar\AppData\Local\Temp\mem_validation\dcd.bin
DEBUG:backend:> To address: 0x34000300
DEBUG:backend:[ SerialLib ] Writing symbol
DEBUG:backend:> Symbol: g_params.function
DEBUG:backend:> Value: 0
DEBUG:backend:> Symbol: g_params.result_status
DEBUG:backend:> Symbol: g_params.num_logged_items
DEBUG:backend:> Symbol: g_params.log_addr
DEBUG:backend:> Value: 876675072
DEBUG:backend:> Symbol: g_params.log_types
DEBUG:backend:> Value: 1023
DEBUG:backend:> Symbol: g_params.log_upper_addr_limit
DEBUG:backend:> Value: 876744704
DEBUG:backend:> Symbol: g_params.swap_enable
DEBUG:backend:> Symbol: g_params.ccsr_phy1_addr
DEBUG:backend:> Value: 1077411840
DEBUG:backend:> Symbol: g_params.ccsr_phy2_addr
DEBUG:backend:> Value: 23068672
DEBUG:backend:> Symbol: g_params.reg_map_compression_ver
DEBUG:backend:> Value: 3
DEBUG:backend:> Symbol: g_params.imem_fw_source_1d
DEBUG:backend:> Value: 872759296
DEBUG:backend:> Symbol: g_params.imem_fw_destination_1d
DEBUG:backend:> Value: 327680
DEBUG:backend:> Symbol: g_params.imem_fw_size_1d
DEBUG:backend:> Value: 32428
DEBUG:backend:> Symbol: g_params.dmem_fw_source_1d
DEBUG:backend:> Value: 872792320
DEBUG:backend:> Symbol: g_params.dmem_fw_destination_1d
DEBUG:backend:> Value: 344064
DEBUG:backend:> Symbol: g_params.dmem_fw_size_1d
DEBUG:backend:> Value: 1660
DEBUG:backend:> Symbol: g_params.imem_fw_source_2d
DEBUG:backend:> Value: 872796160
DEBUG:backend:> Symbol: g_params.imem_fw_destination_2d
DEBUG:backend:> Symbol: g_params.imem_fw_size_2d
DEBUG:backend:> Value: 25504
DEBUG:backend:> Symbol: g_params.dmem_fw_source_2d
DEBUG:backend:> Value: 872824832
DEBUG:backend:> Symbol: g_params.dmem_fw_destination_2d
DEBUG:backend:> Symbol: g_params.dmem_fw_size_2d
DEBUG:backend:> Value: 1404
DEBUG:backend:> Symbol: g_params.train_2d
DEBUG:backend:> Symbol: g_params.ctrl_id
DEBUG:backend:> Symbol: g_params.dram_type
DEBUG:backend:> Symbol: g_params.dimm_type
DEBUG:backend:> Value: 4
DEBUG:backend:> Symbol: g_params.frequency
DEBUG:backend:> Value: 800
DEBUG:backend:> Symbol: g_params.hard_macro_ver
DEBUG:backend:> Symbol: g_params.num_dbyte
DEBUG:backend:> Symbol: g_params.num_active_dbyte_dfi0
DEBUG:backend:> Symbol: g_params.num_anib
DEBUG:backend:> Symbol: g_params.num_rank_dfi0
DEBUG:backend:> Symbol: g_params.num_rank_dfi1
DEBUG:backend:> Symbol: g_params.num_pstates
DEBUG:backend:> Symbol: g_params.pll_bypass
DEBUG:backend:> Symbol: g_params.dfi_freq_ratio
DEBUG:backend:> Symbol: g_params.read_dbi_enable
DEBUG:backend:> Symbol: g_params.dfi1_exists
DEBUG:backend:> Symbol: g_params.dram_data_width
DEBUG:backend:> Symbol: g_params.dram_byte_swap
DEBUG:backend:> Symbol: g_params.ext_cal_res_val
DEBUG:backend:> Symbol: g_params.tx_slew_rise_dq
DEBUG:backend:> Value: 15
DEBUG:backend:> Symbol: g_params.tx_slew_fall_dq
DEBUG:backend:> Symbol: g_params.tx_slew_rise_ac
DEBUG:backend:> Symbol: g_params.tx_slew_fall_ac
DEBUG:backend:> Symbol: g_params.odt_impedance
DEBUG:backend:> Value: 60
DEBUG:backend:> Symbol: g_params.tx_impedance
DEBUG:backend:> Value: 40
DEBUG:backend:> Symbol: g_params.atx_impedance
DEBUG:backend:> Symbol: g_params.mem_alert_en
DEBUG:backend:> Symbol: g_params.mem_alert_pu_imp
DEBUG:backend:> Value: 5
DEBUG:backend:> Symbol: g_params.mem_alert_vref_level
DEBUG:backend:> Value: 41
DEBUG:backend:> Symbol: g_params.mem_alert_sync_bypass
DEBUG:backend:> Symbol: g_params.cal_interval
DEBUG:backend:> Value: 9
DEBUG:backend:> Symbol: g_params.cal_once
DEBUG:backend:> Symbol: g_params.dis_dyn_adr_tri
DEBUG:backend:> Symbol: g_params.is2t_timing
DEBUG:backend:> Symbol: g_params.d4rx_preamble_length
DEBUG:backend:> Symbol: g_params.d4tx_preamble_length
DEBUG:backend:> Symbol: g_params.decision_feedback_eq
DEBUG:backend:> Symbol: g_params.phy_odt_impedance
DEBUG:backend:> Symbol: g_params.phy_drv_impedance
DEBUG:backend:> Symbol: g_params.msg_misc
DEBUG:backend:> Symbol: g_params.hdt_ctrl
DEBUG:backend:> Symbol: g_params.cs_present
DEBUG:backend:> Symbol: g_params.cs_present_d0
DEBUG:backend:> Symbol: g_params.cs_present_d1
DEBUG:backend:> Symbol: g_params.phy_vref
DEBUG:backend:> Value: 24
DEBUG:backend:> Symbol: g_params.dfi_mrl_margin
DEBUG:backend:> Symbol: g_params.addr_mirror
DEBUG:backend:> Symbol: g_params.wr_odt_pat_rank0
DEBUG:backend:> Symbol: g_params.wr_odt_pat_rank1
DEBUG:backend:> Symbol: g_params.wr_odt_pat_rank2
DEBUG:backend:> Symbol: g_params.wr_odt_pat_rank3
DEBUG:backend:> Symbol: g_params.rd_odt_pat_rank0
DEBUG:backend:> Symbol: g_params.rd_odt_pat_rank1
DEBUG:backend:> Symbol: g_params.rd_odt_pat_rank2
DEBUG:backend:> Symbol: g_params.rd_odt_pat_rank3
DEBUG:backend:> Symbol: g_params.d4_misc
DEBUG:backend:> Symbol: g_params.disabled_dbyte
DEBUG:backend:> Symbol: g_params.sequence_ctrl
DEBUG:backend:> Value: 4895
DEBUG:backend:> Symbol: g_params.sequence_ctrl_2d
DEBUG:backend:> Value: 97
DEBUG:backend:> Symbol: g_params.rtt_nom_wr_park0
DEBUG:backend:> Symbol: g_params.rtt_nom_wr_park1
DEBUG:backend:> Symbol: g_params.rtt_nom_wr_park2
DEBUG:backend:> Symbol: g_params.rtt_nom_wr_park3
DEBUG:backend:> Symbol: g_params.rtt_nom_wr_park4
DEBUG:backend:> Symbol: g_params.rtt_nom_wr_park5
DEBUG:backend:> Symbol: g_params.rtt_nom_wr_park6
DEBUG:backend:> Symbol: g_params.rtt_nom_wr_park7
DEBUG:backend:> Symbol: g_params.share_2d_vref_result
DEBUG:backend:> Symbol: g_params.delay_weight_2d
DEBUG:backend:> Value: 128
DEBUG:backend:> Symbol: g_params.voltage_weight_2d
DEBUG:backend:> Symbol: g_params.mr0
DEBUG:backend:> Value: 12292
DEBUG:backend:> Symbol: g_params.mr1
DEBUG:backend:> Symbol: g_params.mr2
DEBUG:backend:> Symbol: g_params.mr3
DEBUG:backend:> Value: 1088
DEBUG:backend:> Symbol: g_params.mr4
DEBUG:backend:> Value: 4608
DEBUG:backend:> Symbol: g_params.mr5
DEBUG:backend:> Value: 5696
DEBUG:backend:> Symbol: g_params.mr6
DEBUG:backend:> Value: 4096
DEBUG:backend:> Symbol: g_params.atx_delay
DEBUG:backend:> Symbol: g_params.atx_delay_en
DEBUG:backend:> Symbol: g_params.rx2d_train_opt
DEBUG:backend:> Symbol: g_params.tx2d_train_opt
DEBUG:backend:> Symbol: g_params.train_opt_en
DEBUG:backend:> Symbol: g_params.train_count_1d
DEBUG:backend:> Symbol: g_params.train_count_2d
DEBUG:backend:> Symbol: g_params.diag_imem_fw_source
DEBUG:backend:> Value: 873095168
DEBUG:backend:> Symbol: g_params.diag_imem_fw_destination
DEBUG:backend:> Symbol: g_params.diag_imem_fw_size
DEBUG:backend:> Value: 22496
DEBUG:backend:> Symbol: g_params.diag_dmem_fw_source
DEBUG:backend:> Value: 873117664
DEBUG:backend:> Symbol: g_params.diag_dmem_fw_destination
DEBUG:backend:> Value: 344576
DEBUG:backend:> Symbol: g_params.diag_dmem_fw_size
DEBUG:backend:> Value: 6900
DEBUG:backend:> Symbol: g_params.diag_test
DEBUG:backend:> Symbol: g_params.diag_subtest
DEBUG:backend:> Symbol: g_params.diag_out_addr_hi
DEBUG:backend:> Symbol: g_params.diag_out_addr_lo
DEBUG:backend:> Value: 873124824
DEBUG:backend:> Symbol: g_params.diag_cs
DEBUG:backend:> Symbol: g_params.diag_r_count
DEBUG:backend:> Symbol: g_params.diag_l_count
DEBUG:backend:> Symbol: g_params.diag_x_count
DEBUG:backend:> Symbol: g_params.diag_seed
DEBUG:backend:> Value: 65535
DEBUG:backend:> Symbol: g_params.diag_prbs
DEBUG:backend:> Symbol: g_params.diag_byte
DEBUG:backend:> Symbol: g_params.diag_lane
DEBUG:backend:> Symbol: g_params.diag_test_addr
DEBUG:backend:> Symbol: g_params.lp4_use_broadcast_mr
DEBUG:backend:> Symbol: g_params.lp4_ca_terminating_rank_ch_a
DEBUG:backend:> Symbol: g_params.lp4_ca_terminating_rank_ch_b
DEBUG:backend:> Symbol: g_params.lp4_mr1
DEBUG:backend:> Value: 36
DEBUG:backend:> Symbol: g_params.lp4_mr2
DEBUG:backend:> Value: 18
DEBUG:backend:> Symbol: g_params.lp4_mr3
DEBUG:backend:> Value: 51
DEBUG:backend:> Symbol: g_params.lp4_mr4
DEBUG:backend:> Symbol: g_params.lp4_mr11
DEBUG:backend:> Symbol: g_params.lp4_mr12
DEBUG:backend:> Value: 77
DEBUG:backend:> Symbol: g_params.lp4_mr13
DEBUG:backend:> Symbol: g_params.lp4_mr14
DEBUG:backend:> Value: 79
DEBUG:backend:> Symbol: g_params.lp4_mr16
DEBUG:backend:> Symbol: g_params.lp4_mr17
DEBUG:backend:> Symbol: g_params.lp4_mr22
DEBUG:backend:> Symbol: g_params.lp4_mr24
DEBUG:backend:> Symbol: g_params.lp4_wdqsext
DEBUG:backend:> Symbol: g_params.lp4_lp4x_mode
DEBUG:backend:> Symbol: g_params.lp4_misc
DEBUG:backend:> Symbol: g_params.lp4_ca_train_opt_en
DEBUG:backend:> Symbol: g_params.log_io_addr
DEBUG:backend:> Value: 876748800
DEBUG:backend:> Symbol: g_params.log_io_upper_addr_limit
DEBUG:backend:> Value: 877797376
DEBUG:backend:> Symbol: g_params.num_logged_io_items
DEBUG:backend:> Symbol: g_params.lane_0_dq_map
DEBUG:backend:> Value: 1985229328
DEBUG:backend:> Symbol: g_params.lane_1_dq_map
DEBUG:backend:> Symbol: g_params.lane_2_dq_map
DEBUG:backend:> Symbol: g_params.lane_3_dq_map
DEBUG:backend:> Symbol: g_params.static_refresh_rate
DEBUG:backend:> From File: D:\NXP_Platform\eclipse\mcu_data\processors\S32G399A\PlatformSDK_S32XX_4_0_0\scripts\ddrv\binaries\firmware\lpddr4_pmu_train_dmem.bin
DEBUG:backend:> To address: 0x3405c100
DEBUG:backend:> From File: D:\NXP_Platform\eclipse\mcu_data\processors\S32G399A\PlatformSDK_S32XX_4_0_0\scripts\ddrv\binaries\firmware\lpddr4_pmu_train_imem.bin
DEBUG:backend:> To address: 0x34054000
DEBUG:backend:> From File: D:\NXP_Platform\eclipse\mcu_data\processors\S32G399A\PlatformSDK_S32XX_4_0_0\scripts\ddrv\binaries\firmware\lpddr4_2d_pmu_train_dmem.bin
DEBUG:backend:> To address: 0x34064000
DEBUG:backend:> From File: D:\NXP_Platform\eclipse\mcu_data\processors\S32G399A\PlatformSDK_S32XX_4_0_0\scripts\ddrv\binaries\firmware\lpddr4_2d_pmu_train_imem.bin
DEBUG:backend:> To address: 0x3405d000
DEBUG:backend:> Symbol: TEST_OUT.appState
DEBUG:backend:> Value: 2857740885
INFO:gdbcommands.commands:Completed DDR data preparation
INFO:gdbcommands.commands:Running DDR training
DEBUG:backend:[ SerialLib ] Reading symbol
DEBUG:utils.serial_lib:Read value 00000003
INFO:gdbcommands.commands:Training finished with code : 3
INFO:gdbcommands.commands:Collecting logs
DEBUG:utils.serial_lib:Read value 00000001
DEBUG:backend:[ SerialLib ] Reading memory
DEBUG:backend:> From address: 0x34410000
DEBUG:backend:> Size: 0x800
DEBUG:backend:> Access size: 1
DEBUG:utils.serial_lib:Read value FF000000000000000000000000000000000000000000000000
DEBUG:backend:> From address: 0x34410800
DEBUG:utils.serial_lib:Read value 00000000000000000000000000000000000000000000000000
Firmware has failed (firmware completed)
ERROR:test:Traceback (most recent call last):
File "D:\NXP_Platform\eclipse\mcu_data\processors\S32G399A\PlatformSDK_S32XX_4_0_0\scripts\ddrv\scripts/test.py", line 99, in run
self.prepare_app()
File "D:\NXP_Platform\eclipse\mcu_data\processors\S32G399A\PlatformSDK_S32XX_4_0_0\scripts\ddrv\scripts/test.py", line 146, in prepare_app
phy.execute_operation(CwPhy.OP_FULL_INIT)
File "D:\NXP_Platform\eclipse\mcu_data\processors\S32G399A\PlatformSDK_S32XX_4_0_0\scripts\ddrv\scripts/gdbcommands/commands.py", line 962, in execute_operation
self.__execute_algorithm()
File "D:\NXP_Platform\eclipse\mcu_data\processors\S32G399A\PlatformSDK_S32XX_4_0_0\scripts\ddrv\scripts/gdbcommands/commands.py", line 844, in __execute_algorithm
self.display_error_message(result_status)
File "D:\NXP_Platform\eclipse\mcu_data\processors\S32G399A\PlatformSDK_S32XX_4_0_0\scripts\ddrv\scripts/gdbcommands/commands.py", line 1387, in display_error_message
raise PhyTrainingException(self.get_error_message(result_status))
PhyTrainingException: DDR PHY: 1D training failed
****DONE****
DEBUG:backend:Executing: quit
chenyin_h
Hi, @jh_park_nt
Thanks for your reply.
I have checked the parameters from you, it seems correct and work fine from my side on local board,  from the two tests done from your side, it seems to be a HW issue of the DDR. I suggest contacting  your DFAE/FAE to verify if a replacement could be requested.
Sorry for your inconvenience.
Chenyin
chenyin_h
Hi, @jh_park_nt
Chenyin
jh_park_nt
Thank you for your response.
Based on your suggestion, we will contact our DFAE/FAE to inquire about a possible replacement.
chenyin_h
Hi, @jh_park_nt
I am sorry to hear that there is DDR issues on your GldBOX.
It seems like a HW issue, but may I know if you have tested it with other pre-built images from latest BSP image? I suggest firstly using another SD card with pre-built images flashed(like BSP42), then try it on the board to check the full log.
Since you have tested it with DDR tools, would you mind also sharing the parameters used for your validation test, which could be found from DDR View of the tool.
Chenyin
Chenyin
jh_park_nt
We used the other SD card provided in the GoldBox 3 package, and the full boot log is as follows:
U-Boot 2020.04+g6286902c94 (Nov 17 2021 - 08:47:30 +0000)
CPU: NXP S32G399A rev. 1.1.0
Reset cause: Power-On Reset
Model: NXP S32G3XX
Board: NXP S32G399A-RDB3
DRAM: Error 3 on ddr_init
initcall sequence 000000003410be40 failed at call 00000000340a2f18 (err=3)
### ERROR ### Please RESET the board ###
We are using the default parameters in the DDR View tool:
Device Information
Clock Cycle Freq (MHz) : 800MHz
Density per channel (Gb) : 8G
Number of Chip Selects used : 2
Number of Channels : 2
Number of COLUMN Adderesses : 10
Number of BANK addresses : 3
Inintial Board Settings
PHY ODT Impedance : 60 Ohm
PHY Drive Strength : 40 Ohm
PHY Vref Quotient : 0x18
DRAM ODT Impedance : 40 Ohm
DRAM Drive Strength : 40 Ohm
CA Vref Training : yes
ECC options
Enable Inline ECC : yes
Train 2D : yes
PHY Log Level : Firmware complete
Refresh Command Constraints : Legacy
Static Refresh Rate [0.25x] : no
Per Bank Refresh : no
DQ Swapping
the mapping is 1-to-1 (e.g., DQ31 = 31, DQ30 = 30, ..., DQ0 = 0).
Code Generation
Code format : U-boot
Advanced Settings
Disable PMIC watchdog : no
Please let us know if you need further details or additional logs.
%3CLINGO-SUB%20id%3D%22lingo-sub-2003520%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G399A%20LinuxBSP_42.0%20Boot%20DDR%20ERROR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2003520%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EWe%20have%20a%20GoldBox%203%20Vehicle%20Networking%20Development%20Platform%2C%20but%20we%20are%20unable%20to%20make%20it%20boot.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBoot%20log%20full%20ouput%20%3A%3C%2FP%3E%3CP%3ENOTICE%3A%20Reset%20status%3A%20Power-On%20Reset%3CBR%20%2F%3EERROR%3A%20Failed%20to%20configure%20the%20DDR%20subsystem%3CBR%20%2F%3EPANIC%20at%20PC%20%3A%200x000000000000003f%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWe%20found%20a%20similar%20question%20on%20the%20following%20link%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G%2FS32G3-VPN-Linux-BSP-Won-t-Boot-DDR-Error%2Fm-p%2F1998154%23M11789%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G%2FS32G3-VPN-Linux-BSP-Won-t-Boot-DDR-Error%2Fm-p%2F1998154%23M11789%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESo%20We%20tried%20using%20Serial%20Boot%20with%20S32%20Design%20Studio%203.5%2C%20and%20we%20got%20the%20following%20log%3A%3C%2FP%3E%3CP%3ED%3A%5CNXP_Platform%5Ceclipse%26gt%3BD%3A%5CNXP_Platform%5CS32DS%5Cbuild_tools%5Cmsys32%5Cmingw32%5Cbin%5Cpython2%20D%3A%5CNXP_Platform%5Ceclipse%5Cmcu_data%5Cprocessors%5CS32G399A%5CPlatformSDK_S32XX_4_0_0%5Cscripts%5Cddrv%5Cscripts%5Cs.py%20-l%20DEBUG%20-parentPID%208464%20%22C%3A%2FUsers%2Fjhpar%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fconnect.json%22%20%22C%3A%2FUsers%2Fjhpar%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Ftest.json%22%20%22C%3A%2FUsers%2Fjhpar%2FAppData%2FLocal%2FTemp%2Fmem_validation%2Fphy.json%22%3CBR%20%2F%3EDEBUG%3Atest%3AInitializing%20test%3CBR%20%2F%3EINFO%3Atest%3AUsing%20binary%20D%3A%2FNXP_Platform%2Feclipse%2Fmcu_data%2Fprocessors%2FS32G399A%2FPlatformSDK_S32XX_4_0_0%2Fscripts%2Fddrv%2Fbinaries%2FS32G3_M7_A53.bin%3CBR%20%2F%3EDEBUG%3Abackend%3AExecuting%3A%20set%20remotetimeout%2060000%3CBR%20%2F%3EDEBUG%3Abackend%3AExecuting%3A%20set%20debug%20remote%200%3CBR%20%2F%3EDEBUG%3Abackend%3AExecuting%3A%20set%20interactive-mode%20off%3CBR%20%2F%3EDEBUG%3Abackend%3AExecuting%3A%20set%20pagination%20off%3CBR%20%2F%3EDEBUG%3Abackend%3AExecuting%3A%20set%20print%20repeats%200%3CBR%20%2F%3EDEBUG%3Abackend%3AExecuting%3A%20disconnect%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3AApp%20path%20D%3A%2FNXP_Platform%2Feclipse%2Fmcu_data%2Fprocessors%2FS32G399A%2FPlatformSDK_S32XX_4_0_0%2Fscripts%2Fddrv%2Fbinaries%2FS32G3_M7_A53.bin%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3Aestablishing%20bootrom%20connection%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3AHEADER%20%3A%3CBR%20%2F%3E%5B'0xd8'%2C%20'0x0'%2C%20'0x0'%2C%20'0x60'%2C%20'0x0'%2C%20'0x0'%2C%20'0x30'%2C%20'0x34'%2C%20'0x0'%2C%20'0x0'%2C%20'0x30'%2C%20'0x34'%2C%20'0x50'%2C%20'0x31'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%2C%20'0x0'%5D%3CBR%20%2F%3EINFO%3Autils.serial_lib%3AWriting%20firmware.%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3A12624%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3A1%20%2F%204%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3A2%20%2F%204%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3A3%20%2F%204%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3A4%20%2F%204%3CBR%20%2F%3EINFO%3Autils.serial_lib%3AWriting%20firmware%20completed.%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3Aestablishing%20master%20connection%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3ARequested%20ACK%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3AReceived%20ACK%3CBR%20%2F%3EDEBUG%3Agdbcommands.commands%3A----------------------------------%3CBR%20%2F%3EDEBUG%3Agdbcommands.commands%3AC%3A%5CUsers%5Cjhpar%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cphy.json%3CBR%20%2F%3EINFO%3Agdbcommands.commands%3APreparing%20DDR%20training%20data%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3ARead%20value%20FEDC8855%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20file%20to%20memory%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20From%20File%3A%20D%3A%2FNXP_Platform%2Feclipse%2Fmcu_data%2Fprocessors%2FS32G399A%2FPlatformSDK_S32XX_4_0_0%2Fscripts%2Fddrv%2Fbinaries%2Fphy%2Fg3_phy.bin%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20To%20address%3A%200x34000000%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20file%20to%20memory%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20From%20File%3A%20C%3A%5CUsers%5Cjhpar%5CAppData%5CLocal%5CTemp%5Cmem_validation%5Cdcd.bin%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20To%20address%3A%200x34000300%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.function%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.result_status%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.num_logged_items%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.log_addr%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20876675072%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.log_types%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201023%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.log_upper_addr_limit%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20876744704%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.swap_enable%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.ccsr_phy1_addr%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201077411840%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.ccsr_phy2_addr%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2023068672%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.reg_map_compression_ver%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%203%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.imem_fw_source_1d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20872759296%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.imem_fw_destination_1d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20327680%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.imem_fw_size_1d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2032428%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dmem_fw_source_1d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20872792320%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dmem_fw_destination_1d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20344064%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dmem_fw_size_1d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201660%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.imem_fw_source_2d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20872796160%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.imem_fw_destination_2d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20327680%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.imem_fw_size_2d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2025504%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dmem_fw_source_2d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20872824832%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dmem_fw_destination_2d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20344064%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dmem_fw_size_2d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201404%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.train_2d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.ctrl_id%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dram_type%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%202%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dimm_type%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%204%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.frequency%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20800%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.hard_macro_ver%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%204%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.num_dbyte%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%204%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.num_active_dbyte_dfi0%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%202%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.num_anib%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2010%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.num_rank_dfi0%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%202%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.num_rank_dfi1%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%202%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.num_pstates%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.pll_bypass%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dfi_freq_ratio%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.read_dbi_enable%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dfi1_exists%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dram_data_width%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2016%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dram_byte_swap%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.ext_cal_res_val%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.tx_slew_rise_dq%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2015%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.tx_slew_fall_dq%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2015%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.tx_slew_rise_ac%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2015%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.tx_slew_fall_ac%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2015%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.odt_impedance%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2060%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.tx_impedance%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2040%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.atx_impedance%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2040%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.mem_alert_en%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.mem_alert_pu_imp%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%205%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.mem_alert_vref_level%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2041%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.mem_alert_sync_bypass%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.cal_interval%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%209%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.cal_once%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dis_dyn_adr_tri%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.is2t_timing%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.d4rx_preamble_length%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.d4tx_preamble_length%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.decision_feedback_eq%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.phy_odt_impedance%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.phy_drv_impedance%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.msg_misc%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.hdt_ctrl%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20255%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.cs_present%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%203%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.cs_present_d0%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%203%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.cs_present_d1%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.phy_vref%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2024%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.dfi_mrl_margin%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%203%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.addr_mirror%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.wr_odt_pat_rank0%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.wr_odt_pat_rank1%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%202%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.wr_odt_pat_rank2%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.wr_odt_pat_rank3%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rd_odt_pat_rank0%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2032%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rd_odt_pat_rank1%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2016%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rd_odt_pat_rank2%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rd_odt_pat_rank3%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.d4_misc%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.disabled_dbyte%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.sequence_ctrl%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%204895%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.sequence_ctrl_2d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2097%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rtt_nom_wr_park0%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rtt_nom_wr_park1%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rtt_nom_wr_park2%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rtt_nom_wr_park3%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rtt_nom_wr_park4%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rtt_nom_wr_park5%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rtt_nom_wr_park6%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rtt_nom_wr_park7%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.share_2d_vref_result%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.delay_weight_2d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20128%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.voltage_weight_2d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2032%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.mr0%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2012292%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.mr1%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.mr2%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2048%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.mr3%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201088%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.mr4%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%204608%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.mr5%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%205696%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.mr6%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%204096%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.atx_delay%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.atx_delay_en%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.rx2d_train_opt%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.tx2d_train_opt%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.train_opt_en%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.train_count_1d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.train_count_2d%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_imem_fw_source%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20873095168%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_imem_fw_destination%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20327680%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_imem_fw_size%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2022496%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_dmem_fw_source%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20873117664%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_dmem_fw_destination%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20344576%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_dmem_fw_size%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%206900%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_test%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%205%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_subtest%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_out_addr_hi%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_out_addr_lo%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20873124824%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_cs%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_r_count%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2032%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_l_count%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2016%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_x_count%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2032%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_seed%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2065535%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_prbs%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_byte%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_lane%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.diag_test_addr%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%204096%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_use_broadcast_mr%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_ca_terminating_rank_ch_a%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_ca_terminating_rank_ch_b%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr1%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2036%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr2%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2018%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr3%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2051%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr4%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr11%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20102%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr12%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2077%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr13%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%208%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr14%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%2079%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr16%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr17%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr22%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%204%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_mr24%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_wdqsext%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_lp4x_mode%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_misc%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lp4_ca_train_opt_en%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.log_io_addr%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20876748800%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.log_io_upper_addr_limit%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%20877797376%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.num_logged_io_items%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lane_0_dq_map%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201985229328%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lane_1_dq_map%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201985229328%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lane_2_dq_map%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201985229328%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.lane_3_dq_map%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%201985229328%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.static_refresh_rate%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%200%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20file%20to%20memory%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20From%20File%3A%20D%3A%5CNXP_Platform%5Ceclipse%5Cmcu_data%5Cprocessors%5CS32G399A%5CPlatformSDK_S32XX_4_0_0%5Cscripts%5Cddrv%5Cbinaries%5Cfirmware%5Clpddr4_pmu_train_dmem.bin%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20To%20address%3A%200x3405c100%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20file%20to%20memory%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20From%20File%3A%20D%3A%5CNXP_Platform%5Ceclipse%5Cmcu_data%5Cprocessors%5CS32G399A%5CPlatformSDK_S32XX_4_0_0%5Cscripts%5Cddrv%5Cbinaries%5Cfirmware%5Clpddr4_pmu_train_imem.bin%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20To%20address%3A%200x34054000%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20file%20to%20memory%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20From%20File%3A%20D%3A%5CNXP_Platform%5Ceclipse%5Cmcu_data%5Cprocessors%5CS32G399A%5CPlatformSDK_S32XX_4_0_0%5Cscripts%5Cddrv%5Cbinaries%5Cfirmware%5Clpddr4_2d_pmu_train_dmem.bin%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20To%20address%3A%200x34064000%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20file%20to%20memory%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20From%20File%3A%20D%3A%5CNXP_Platform%5Ceclipse%5Cmcu_data%5Cprocessors%5CS32G399A%5CPlatformSDK_S32XX_4_0_0%5Cscripts%5Cddrv%5Cbinaries%5Cfirmware%5Clpddr4_2d_pmu_train_imem.bin%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20To%20address%3A%200x3405d000%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Writing%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20TEST_OUT.appState%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Value%3A%202857740885%3CBR%20%2F%3EINFO%3Agdbcommands.commands%3ACompleted%20DDR%20data%20preparation%3CBR%20%2F%3EINFO%3Agdbcommands.commands%3ARunning%20DDR%20training%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3ARead%20value%20FEDC8855%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Reading%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.result_status%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3ARead%20value%2000000003%3CBR%20%2F%3EINFO%3Agdbcommands.commands%3ATraining%20finished%20with%20code%20%3A%203%3CBR%20%2F%3EINFO%3Agdbcommands.commands%3ACollecting%20logs%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Reading%20symbol%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Symbol%3A%20g_params.num_logged_items%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3ARead%20value%2000000001%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Reading%20memory%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20From%20address%3A%200x34410000%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Size%3A%200x800%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Access%20size%3A%201%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3ARead%20value%20FF000000000000000000000000000000000000000000000000%3CBR%20%2F%3EDEBUG%3Abackend%3A%5B%20SerialLib%20%5D%20Reading%20memory%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20From%20address%3A%200x34410800%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Size%3A%200x800%3CBR%20%2F%3EDEBUG%3Abackend%3A%26gt%3B%20Access%20size%3A%201%3CBR%20%2F%3EDEBUG%3Autils.serial_lib%3ARead%20value%2000000000000000000000000000000000000000000000000000%3CBR%20%2F%3EFirmware%20has%20failed%20(firmware%20completed)%3C%2FP%3E%3CP%3EERROR%3Atest%3ATraceback%20(most%20recent%20call%20last)%3A%3CBR%20%2F%3EFile%20%22D%3A%5CNXP_Platform%5Ceclipse%5Cmcu_data%5Cprocessors%5CS32G399A%5CPlatformSDK_S32XX_4_0_0%5Cscripts%5Cddrv%5Cscripts%2Ftest.py%22%2C%20line%2099%2C%20in%20run%3CBR%20%2F%3Eself.prepare_app()%3CBR%20%2F%3EFile%20%22D%3A%5CNXP_Platform%5Ceclipse%5Cmcu_data%5Cprocessors%5CS32G399A%5CPlatformSDK_S32XX_4_0_0%5Cscripts%5Cddrv%5Cscripts%2Ftest.py%22%2C%20line%20146%2C%20in%20prepare_app%3CBR%20%2F%3Ephy.execute_operation(CwPhy.OP_FULL_INIT)%3CBR%20%2F%3EFile%20%22D%3A%5CNXP_Platform%5Ceclipse%5Cmcu_data%5Cprocessors%5CS32G399A%5CPlatformSDK_S32XX_4_0_0%5Cscripts%5Cddrv%5Cscripts%2Fgdbcommands%2Fcommands.py%22%2C%20line%20962%2C%20in%20execute_operation%3CBR%20%2F%3Eself.__execute_algorithm()%3CBR%20%2F%3EFile%20%22D%3A%5CNXP_Platform%5Ceclipse%5Cmcu_data%5Cprocessors%5CS32G399A%5CPlatformSDK_S32XX_4_0_0%5Cscripts%5Cddrv%5Cscripts%2Fgdbcommands%2Fcommands.py%22%2C%20line%20844%2C%20in%20__execute_algorithm%3CBR%20%2F%3Eself.display_error_message(result_status)%3CBR%20%2F%3EFile%20%22D%3A%5CNXP_Platform%5Ceclipse%5Cmcu_data%5Cprocessors%5CS32G399A%5CPlatformSDK_S32XX_4_0_0%5Cscripts%5Cddrv%5Cscripts%2Fgdbcommands%2Fcommands.py%22%2C%20line%201387%2C%20in%20display_error_message%3CBR%20%2F%3Eraise%20PhyTrainingException(self.get_error_message(result_status))%3CBR%20%2F%3EPhyTrainingException%3A%20DDR%20PHY%3A%201D%20training%20failed%3C%2FP%3E%3CP%3E****DONE****%3CBR%20%2F%3EDEBUG%3Abackend%3AExecuting%3A%20quit%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2004152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G399A%20LinuxBSP_42.0%20Boot%20DDR%20ERROR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2004152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20for%20your%20response.%3CBR%20%2F%3E%3CBR%20%2F%3EBased%20on%20your%20suggestion%2C%20we%20will%20contact%20our%20DFAE%2FFAE%20to%20inquire%20about%20a%20possible%20replacement.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2004127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G399A%20LinuxBSP_42.0%20Boot%20DDR%20ERROR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2004127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243947%22%20target%3D%22_blank%22%3E%40jh_park_nt%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EI%20have%20checked%20the%20parameters%20from%20you%2C%20it%20seems%20correct%20and%20work%20fine%20from%20my%20side%20on%20local%20board%2C%26nbsp%3B%3CSPAN%3E%26nbsp%3Bfrom%20the%20two%20tests%20done%20from%20your%20side%2C%20it%20seems%20to%20be%20a%20HW%20issue%20of%20the%20DDR.%20I%20suggest%20contacting%26nbsp%3B%20your%20DFAE%2FFAE%20to%20verify%20if%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3Ba%20replacement%20could%20be%20requested.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ESorry%20for%20your%20inconvenience.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EChenyin%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2004012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G399A%20LinuxBSP_42.0%20Boot%20DDR%20ERROR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2004012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20for%20your%20response.%3CBR%20%2F%3E%3CBR%20%2F%3EWe%20used%20the%20other%20SD%20card%20provided%20in%20the%20GoldBox%203%20package%2C%20and%20the%20full%20boot%20log%20is%20as%20follows%3A%3CBR%20%2F%3EU-Boot%202020.04%2Bg6286902c94%20(Nov%2017%202021%20-%2008%3A47%3A30%20%2B0000)%3CBR%20%2F%3E%3CBR%20%2F%3ECPU%3A%20NXP%20S32G399A%20rev.%201.1.0%3CBR%20%2F%3EReset%20cause%3A%20Power-On%20Reset%3CBR%20%2F%3EModel%3A%20NXP%20S32G3XX%3CBR%20%2F%3EBoard%3A%20NXP%20S32G399A-RDB3%3CBR%20%2F%3EDRAM%3A%20Error%203%20on%20ddr_init%3CBR%20%2F%3Einitcall%20sequence%20000000003410be40%20failed%20at%20call%2000000000340a2f18%20(err%3D3)%3CBR%20%2F%3E%23%23%23%20ERROR%20%23%23%23%20Please%20RESET%20the%20board%20%23%23%23%3CBR%20%2F%3E%3CBR%20%2F%3EWe%20are%20using%20the%20default%20parameters%20in%20the%20DDR%20View%20tool%3A%3CBR%20%2F%3EDevice%20Information%3CBR%20%2F%3EClock%20Cycle%20Freq%20(MHz)%20%3A%20800MHz%3CBR%20%2F%3EDensity%20per%20channel%20(Gb)%20%3A%208G%3CBR%20%2F%3ENumber%20of%20Chip%20Selects%20used%20%3A%202%3CBR%20%2F%3ENumber%20of%20Channels%20%3A%202%3CBR%20%2F%3ENumber%20of%20COLUMN%20Adderesses%20%3A%2010%3CBR%20%2F%3ENumber%20of%20BANK%20addresses%20%3A%203%3CBR%20%2F%3E%3CBR%20%2F%3EInintial%20Board%20Settings%3CBR%20%2F%3EPHY%20ODT%20Impedance%20%3A%2060%20Ohm%3CBR%20%2F%3EPHY%20Drive%20Strength%20%3A%2040%20Ohm%3CBR%20%2F%3EPHY%20Vref%20Quotient%20%3A%200x18%3CBR%20%2F%3EDRAM%20ODT%20Impedance%20%3A%2040%20Ohm%3CBR%20%2F%3EDRAM%20Drive%20Strength%20%3A%2040%20Ohm%3CBR%20%2F%3ECA%20Vref%20Training%20%3A%20yes%3CBR%20%2F%3E%3CBR%20%2F%3EECC%20options%3CBR%20%2F%3EEnable%20Inline%20ECC%20%3A%20yes%3CBR%20%2F%3ETrain%202D%20%3A%20yes%3CBR%20%2F%3EPHY%20Log%20Level%20%3A%20Firmware%20complete%3CBR%20%2F%3ERefresh%20Command%20Constraints%20%3A%20Legacy%3CBR%20%2F%3EStatic%20Refresh%20Rate%20%5B0.25x%5D%20%3A%20no%3CBR%20%2F%3EPer%20Bank%20Refresh%20%3A%20no%3CBR%20%2F%3E%3CBR%20%2F%3EDQ%20Swapping%3CBR%20%2F%3Ethe%20mapping%20is%201-to-1%20(e.g.%2C%20DQ31%20%3D%2031%2C%20DQ30%20%3D%2030%2C%20...%2C%20DQ0%20%3D%200).%3CBR%20%2F%3E%3CBR%20%2F%3ECode%20Generation%3CBR%20%2F%3ECode%20format%20%3A%20U-boot%3CBR%20%2F%3E%3CBR%20%2F%3EAdvanced%20Settings%3CBR%20%2F%3EDisable%20PMIC%20watchdog%20%3A%20no%3CBR%20%2F%3E%3CBR%20%2F%3EPlease%20let%20us%20know%20if%20you%20need%20further%20details%20or%20additional%20logs.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2003659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G399A%20LinuxBSP_42.0%20Boot%20DDR%20ERROR%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2003659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243947%22%20target%3D%22_blank%22%3E%40jh_park_nt%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20am%20sorry%20to%20hear%20that%20there%20is%20DDR%20issues%20on%20your%20GldBOX.%3C%2FP%3E%0A%3CP%3EIt%20seems%20like%20a%20HW%20issue%2C%20but%20may%20I%20know%20if%20you%20have%20tested%20it%20with%20other%20pre-built%20images%20from%20latest%20BSP%20image%3F%20I%20suggest%20firstly%20using%20another%20SD%20card%20with%20pre-built%20images%20flashed(like%20BSP42)%2C%20then%20try%20it%20on%20the%20board%20to%20check%20the%20full%20log.%3C%2FP%3E%0A%3CP%3ESince%20you%20have%20tested%20it%20with%20DDR%20tools%2C%20would%20you%20mind%20also%20sharing%20the%20parameters%20used%20for%20your%20validation%20test%2C%20which%20could%20be%20found%20from%20DDR%20View%20of%20the%20tool.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
