请问如果直接使用S32G2的GMAC0对其他芯片的MAC,中间没有PHY的连接的话,BSP中需要修改哪些地方才能让GMAC0正常使用?
If you are with the S32G board form NXP you can modify anything since GMAC0 comes with the phy, you have connect phy to other chip is not the case.
