I'm building image for s32g274,
https://github.com/nxp-auto-linux/auto_yocto_bsp/tree/release/bsp36.0
and the detail info as below:
ERROR: fsl-image-base-1.0-r0 do_rootfs: Could not invoke dnf.
Command '/home/chengpeiliang/fsl-auto-yocto-bsp36.0/build_s32g274aevbubuntu/tmp/work/s32g274aevb-fsl-linux/fsl-image-base/1.0-r0/recipe-sysroot-native/usr/bin/dnf
-v --rpmverbosity=info -y -c /home/chengpeiliang/fsl-auto-yocto-bsp36.0/build_s32g274aevbubuntu/tmp/work/s32g274aevb-fsl-linux/fsl-image-base/1.0-r0/rootfs/etc/dnf/dnf.conf
--setopt=reposdir=/home/chengpeiliang/fsl-auto-yocto-bsp36.0/build_s32g274aevbubuntu/tmp/work/s32g274aevb-fsl-linux/fsl-image-base/1.0-r0/rootfs/etc/yum.repos.d
--installroot=/home/chengpeiliang/fsl-auto-yocto-bsp36.0/build_s32g274aevbubuntu/tmp/work/s32g274aevb-fsl-linux/fsl-image-base/1.0-r0/rootfs
--setopt=logdir=/home/chengpeiliang/fsl-auto-yocto-bsp36.0/build_s32g274aevbubuntu/tmp/work/s32g274aevb-fsl-linux/fsl-image-base/1.0-r0/temp
--repofrompath=oe-repo,/home/chengpeiliang/fsl-auto-yocto-bsp36.0/build_s32g274aevbubuntu/tmp/work/s32g274aevb-fsl-linux/fsl-image-base/1.0-r0/oe-rootfs-repo
--nogpgcheck install dhcpcd iputils kernel-image kernel-modules linux-qspi-tool packagegroup-core-boot pciutils rng-tools run-postinsts setserial util-linux-rtcwake' returned 1:
DNF version: 4.11.1
cachedir: /home/chengpeiliang/fsl-auto-yocto-bsp36.0/build_s32g274aevbubuntu/tmp/work/s32g274aevb-fsl-linux/fsl-image-base/1.0-r0/rootfs/var/cache/dnf
Added oe-repo repo from /home/chengpeiliang/fsl-auto-yocto-bsp36.0/build_s32g274aevbubuntu/tmp/work/s32g274aevb-fsl-linux/fsl-image-base/1.0-r0/oe-rootfs-repo
User-Agent: falling back to 'libdnf': could not detect OS or basearch
repo: using cache for: oe-repo
oe-repo: using metadata from Fri 28 Apr 2023 02:18:00 AM UTC.
--> Starting dependency resolution
---> Package busybox-syslog.cortexa53_crypto 1.35.0-r0 will be installed
---> Package dhcpcd.cortexa53_crypto 9.4.1-r0 will be installed
---> Package iputils.cortexa53_crypto 20211215-r0 will be installed
---> Package iputils-arping.cortexa53_crypto 20211215-r0 will be installed
---> Package iputils-clockdiff.cortexa53_crypto 20211215-r0 will be installed
---> Package iputils-ninfod.cortexa53_crypto 20211215-r0 will be installed
---> Package iputils-rarpd.cortexa53_crypto 20211215-r0 will be installed
---> Package iputils-rdisc.cortexa53_crypto 20211215-r0 will be installed
---> Package iputils-tracepath.cortexa53_crypto 20211215-r0 will be installed
---> Package kernel-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-image-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-image-image-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-ip-tables-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-iptable-filter-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-iptable-nat-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-nf-nat-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-x-tables-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-xt-addrtype-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-xt-conntrack-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-xt-ipvs-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-xt-mark-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-xt-masquerade-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-xt-nat-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-module-xt-tcpudp-5.15.85-rt55+g9133b22fcbe1.s32g274aevb 5.15.85-r0 will be installed
---> Package kernel-modules.s32g274aevb 5.15.85-r0 will be installed
---> Package libcap.cortexa53_crypto 2.65-r0 will be installed
---> Package libcrypt2.cortexa53_crypto 4.4.28-r0 will be installed
---> Package libpam.cortexa53_crypto 1.5.2-r0 will be installed
---> Package libpam-runtime.cortexa53_crypto 1.5.2-r0 will be installed
---> Package libpci3.cortexa53_crypto 3.7.0-r0 will be installed
---> Package linux-qspi-tool.cortexa53_crypto 1.0-r0 will be installed
---> Package mtd-utils.cortexa53_crypto 2.1.4-r0 will be installed
---> Package packagegroup-core-boot.s32g274aevb 1.0-r17 will be installed
---> Package pam-plugin-deny.cortexa53_crypto 1.5.2-r0 will be installed
---> Package pam-plugin-mail.cortexa53_crypto 1.5.2-r0 will be installed
---> Package pam-plugin-permit.cortexa53_crypto 1.5.2-r0 will be installed
---> Package pam-plugin-unix.cortexa53_crypto 1.5.2-r0 will be installed
---> Package pam-plugin-warn.cortexa53_crypto 1.5.2-r0 will be installed
---> Package pciutils.cortexa53_crypto 3.7.0-r0 will be installed
---> Package pciutils-ids.cortexa53_crypto 3.7.0-r0 will be installed
---> Package rng-tools.cortexa53_crypto 5-r0 will be installed
---> Package run-postinsts.noarch 1.0-r10 will be installed
---> Package setserial.cortexa53_crypto 2.17-r3 will be installed
---> Package shadow.cortexa53_crypto 4.11.1-r0 will be installed
---> Package shadow-base.cortexa53_crypto 4.11.1-r0 will be installed
---> Package shadow-securetty.s32g274aevb 4.6-r3 will be installed
---> Package ubuntu-base.cortexa53_crypto 22.04.1-r0 will be installed
---> Package ubuntu-base-doc.cortexa53_crypto 22.04.1-r0 will be installed
---> Package util-linux-rtcwake.cortexa53_crypto 2.37.4-r0 will be installed
---> Package util-linux-sulogin.cortexa53_crypto 2.37.4-r0 will be installed
--> Finished dependency resolution
Dependencies resolved.
Package Architecture Version Repo Size
Installing:
dhcpcd cortexa53_crypto 9.4.1-r0 oe-repo 186 k
iputils cortexa53_crypto 20211215-r0 oe-repo 5.8 k
kernel-image-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 5.7 k
kernel-modules s32g274aevb 5.15.85-r0 oe-repo 6.2 k
linux-qspi-tool cortexa53_crypto 1.0-r0 oe-repo 7.1 k
packagegroup-core-boot s32g274aevb 1.0-r17 oe-repo 5.8 k
pciutils cortexa53_crypto 3.7.0-r0 oe-repo 53 k
rng-tools cortexa53_crypto 5-r0 oe-repo 21 k
run-postinsts noarch 1.0-r10 oe-repo 8.9 k
setserial cortexa53_crypto 2.17-r3 oe-repo 15 k
util-linux-rtcwake cortexa53_crypto 2.37.4-r0 oe-repo 29 k
Installing dependencies:
iputils-arping cortexa53_crypto 20211215-r0 oe-repo 16 k
iputils-clockdiff cortexa53_crypto 20211215-r0 oe-repo 13 k
iputils-ninfod cortexa53_crypto 20211215-r0 oe-repo 24 k
iputils-rarpd cortexa53_crypto 20211215-r0 oe-repo 15 k
iputils-rdisc cortexa53_crypto 20211215-r0 oe-repo 19 k
iputils-tracepath cortexa53_crypto 20211215-r0 oe-repo 13 k
kernel-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 23 k
kernel-image-image-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 5.1 M
kernel-module-ip-tables-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 19 k
kernel-module-iptable-filter-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 9.9 k
kernel-module-iptable-nat-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 10 k
kernel-module-nf-nat-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 20 k
kernel-module-x-tables-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 21 k
kernel-module-xt-addrtype-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 9.6 k
kernel-module-xt-conntrack-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 10 k
kernel-module-xt-ipvs-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 10 k
kernel-module-xt-mark-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 9.1 k
kernel-module-xt-masquerade-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 9.6 k
kernel-module-xt-nat-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 10 k
kernel-module-xt-tcpudp-5.15.85-rt55+g9133b22fcbe1 s32g274aevb 5.15.85-r0 oe-repo 9.7 k
libcap cortexa53_crypto 2.65-r0 oe-repo 34 k
libcrypt2 cortexa53_crypto 4.4.28-r0 oe-repo 89 k
libpam cortexa53_crypto 1.5.2-r0 oe-repo 40 k
libpci3 cortexa53_crypto 3.7.0-r0 oe-repo 30 k
mtd-utils cortexa53_crypto 2.1.4-r0 oe-repo 101 k
pam-plugin-deny cortexa53_crypto 1.5.2-r0 oe-repo 7.9 k
pam-plugin-mail cortexa53_crypto 1.5.2-r0 oe-repo 11 k
pam-plugin-permit cortexa53_crypto 1.5.2-r0 oe-repo 8.5 k
pam-plugin-unix cortexa53_crypto 1.5.2-r0 oe-repo 26 k
pam-plugin-warn cortexa53_crypto 1.5.2-r0 oe-repo 8.9 k
pciutils-ids cortexa53_crypto 3.7.0-r0 oe-repo 282 k
shadow cortexa53_crypto 4.11.1-r0 oe-repo 310 k
shadow-base cortexa53_crypto 4.11.1-r0 oe-repo 52 k
shadow-securetty s32g274aevb 4.6-r3 oe-repo 6.8 k
ubuntu-base cortexa53_crypto 22.04.1-r0 oe-repo 131 M
ubuntu-base-doc cortexa53_crypto 22.04.1-r0 oe-repo 23 M
util-linux-sulogin cortexa53_crypto 2.37.4-r0 oe-repo 30 k
Installing weak dependencies:
busybox-syslog cortexa53_crypto 1.35.0-r0 oe-repo 9.9 k
libpam-runtime cortexa53_crypto 1.5.2-r0 oe-repo 45 k
Transaction Summary
Install 50 Packages
Total size: 160 M
Installed size: 556 M
Downloading Packages:
Running transaction check
Transaction check succeeded.
Running transaction test
Error: Transaction test error:
file /etc/environment conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/common-auth conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/common-password conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/common-session conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/common-session-noninteractive conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/other conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/security/limits.conf conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/faillock conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/mkhomedir_helper conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/pam_timestamp_check conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/unix_chkpwd conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/unix_update conflicts between attempted installs of libpam-runtime-1.5.2-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/login.defs conflicts between attempted installs of shadow-base-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/login conflicts between attempted installs of shadow-base-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/su conflicts between attempted installs of shadow-base-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/bin/sg conflicts between attempted installs of shadow-base-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/default/useradd conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/chfn conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/chpasswd conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/chsh conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/newusers conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /etc/pam.d/passwd conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/bin/chage conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/bin/expiry conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/bin/faillog conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/bin/gpasswd conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/bin/lastlog conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/chgpasswd conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/groupadd conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/groupdel conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/groupmems conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/groupmod conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/grpck conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/grpconv conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/grpunconv conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/newusers conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/pwck conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/pwconv conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/pwunconv conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/useradd conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/userdel conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /usr/sbin/usermod conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
file /var/spool/mail conflicts between attempted installs of shadow-4.11.1-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
ERROR: Logfile of failure stored in: /home/chengpeiliang/fsl-auto-yocto-bsp36.0/build_s32g274aevbubuntu/tmp/work/s32g274aevb-fsl-linux/fsl-image-base/1.0-r0/temp/log.do_rootfs.2702433
ERROR: Task (/home/chengpeiliang/fsl-auto-yocto-bsp36.0/sources/meta-alb/recipes-fsl/images/fsl-image-base.bb:do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2472 tasks of which 2452 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message, returning a non-zero exit code.
Dear colleagues,
Has anyone succeeded to identify the issue ? Absolutely the same happens with BSP38 (https://github.com/nxp-auto-linux/auto_yocto_bsp)
for the s32g274ardb2ubuntu machine (see below). What is the resolution ?
ERROR: fsl-image-ubuntu-1.0-r0 do_rootfs: Could not invoke dnf. Command '/home/builder1/work/fsl-auto-yocto-bsp/build_s32g274ardb2ubuntu/tmp/work/s32g274ardb2-fsl-linux/fsl-image-ubuntu/1.0-r0/recipe-sysroot-native/usr/bin/dnf -v --rpmverbosity=info -y -c /home/builder1/work/fsl-auto-yocto-bsp/build_s32g274ardb2ubuntu/tmp/work/s32g274ardb2-fsl-linux/fsl-image-ubuntu/1.0-r0/rootfs/etc/dnf/dnf.conf --setopt=reposdir=/home/builder1/work/fsl-auto-yocto-bsp/build_s32g274ardb2ubuntu/tmp/work/s32g274ardb2-fsl-linux/fsl-image-ubuntu/1.0-r0/rootfs/etc/yum.repos.d --installroot=/home/builder1/work/fsl-auto-yocto-bsp/build_s32g274ardb2ubuntu/tmp/work/s32g274ardb2-fsl-linux/fsl-image-ubuntu/1.0-r0/rootfs --setopt=logdir=/home/builder1/work/fsl-auto-yocto-bsp/build_s32g274ardb2ubuntu/tmp/work/s32g274ardb2-fsl-linux/fsl-image-ubuntu/1.0-r0/temp --repofrompath=oe-repo,/home/builder1/work/fsl-auto-yocto-bsp/build_s32g274ardb2ubuntu/tmp/work/s32g274ardb2-fsl-linux/fsl-image-ubuntu/1.0-r0/oe-rootfs-repo --nogpgcheck install kernel-devicetree kernel-devsrc kernel-image kernel-modules ldd linux-kernelitb-norootfs-image nfs-utils sja1110 ubuntu-base ubuntu-base-dbg ubuntu-base-dev ubuntu-base-doc' returned 1:
DNF version: 4.11.1
cachedir: /home/builder1/work/fsl-auto-yocto-bsp/build_s32g274ardb2ubuntu/tmp/work/s32g274ardb2-fsl-linux/fsl-image-ubuntu/1.0-r0/rootfs/var/cache/dnf
Added oe-repo repo from /home/builder1/work/fsl-auto-yocto-bsp/build_s32g274ardb2ubuntu/tmp/work/s32g274ardb2-fsl-linux/fsl-image-ubuntu/1.0-r0/oe-rootfs-repo
oe-repo: using metadata from Thu 16 Nov 2023 08:01:05 AM UTC.
Last metadata expiration check: 0:00:01 ago on Thu 16 Nov 2023 08:01:05 AM UTC.
---> Package kernel-5.15.119-rt65guardknox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-devicetree.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-devsrc.s32g274ardb2 1.0-r0 will be installed
---> Package kernel-image-5.15.119-rt65guardknox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-image-image-5.15.119-rt65guardknox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-ip-tables-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-iptable-filter-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-iptable-nat-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-nf-nat-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-x-tables-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-xt-addrtype-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-xt-conntrack-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-xt-ipvs-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-xt-mark-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-xt-masquerade-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-xt-nat-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-module-xt-tcpudp-5.15.119-rt65GuardKnox+ge18f05316cd9.s32g274ardb2 5.15.119-r0 will be installed
---> Package kernel-modules.s32g274ardb2 5.15.119-r0 will be installed
---> Package ldd.cortexa53_crypto 2.35-r0 will be installed
---> Package libcap.cortexa53_crypto 2.66-r0 will be installed
---> Package libcrypt2.cortexa53_crypto 4.4.30-r0 will be installed
---> Package libwrap0.cortexa53_crypto 7.6-r10 will be installed
---> Package linux-kernelitb-norootfs-image.cortexa53_crypto 1.0-r0 will be installed
---> Package nfs-utils.cortexa53_crypto 2.6.1-r0 will be installed
---> Package nfs-utils-client.cortexa53_crypto 2.6.1-r0 will be installed
---> Package nfs-utils-mount.cortexa53_crypto 2.6.1-r0 will be installed
---> Package rpcbind.cortexa53_crypto 1.2.6-r0 will be installed
---> Package shadow-securetty.s32g274ardb2 4.6-r3 will be installed
---> Package sja1110.s32g274ardb2 1.0-r0 will be installed
---> Package ubuntu-base-dbg.cortexa53_crypto 22.04.1-r0 will be installed
---> Package ubuntu-base-dev.cortexa53_crypto 22.04.1-r0 will be installed
Installing:
kernel-devicetree s32g274ardb2 5.15.119-r0 oe-repo 15 k
kernel-devsrc s32g274ardb2 1.0-r0 oe-repo 11 M
kernel-image-5.15.119-rt65guardknox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 5.7 k
kernel-modules s32g274ardb2 5.15.119-r0 oe-repo 6.3 k
ldd cortexa53_crypto 2.35-r0 oe-repo 8.6 k
linux-kernelitb-norootfs-image cortexa53_crypto 1.0-r0 oe-repo 6.0 M
nfs-utils cortexa53_crypto 2.6.1-r0 oe-repo 101 k
sja1110 s32g274ardb2 1.0-r0 oe-repo 15 k
ubuntu-base cortexa53_crypto 22.04.1-r0 oe-repo 132 M
ubuntu-base-dbg cortexa53_crypto 22.04.1-r0 oe-repo 10 k
ubuntu-base-dev cortexa53_crypto 22.04.1-r0 oe-repo 5.9 k
kernel-5.15.119-rt65guardknox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 23 k
kernel-image-image-5.15.119-rt65guardknox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 5.1 M
kernel-module-ip-tables-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 19 k
kernel-module-iptable-filter-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 10 k
kernel-module-iptable-nat-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 10 k
kernel-module-nf-nat-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 20 k
kernel-module-x-tables-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 21 k
kernel-module-xt-addrtype-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 9.8 k
kernel-module-xt-conntrack-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 10 k
kernel-module-xt-ipvs-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 10 k
kernel-module-xt-mark-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 9.3 k
kernel-module-xt-masquerade-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 9.8 k
kernel-module-xt-nat-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 10 k
kernel-module-xt-tcpudp-5.15.119-rt65GuardKnox+ge18f05316cd9 s32g274ardb2 5.15.119-r0 oe-repo 9.9 k
libcap cortexa53_crypto 2.66-r0 oe-repo 34 k
libcrypt2 cortexa53_crypto 4.4.30-r0 oe-repo 89 k
libwrap0 cortexa53_crypto 7.6-r10 oe-repo 22 k
nfs-utils-client cortexa53_crypto 2.6.1-r0 oe-repo 85 k
nfs-utils-mount cortexa53_crypto 2.6.1-r0 oe-repo 60 k
rpcbind cortexa53_crypto 1.2.6-r0 oe-repo 47 k
shadow-securetty s32g274ardb2 4.6-r3 oe-repo 6.8 k
Transaction Summary
Install 43 Packages
Total size: 178 M
Installed size: 621 M
file /usr/bin/ldd conflicts between attempted installs of ldd-2.35-r0.cortexa53_crypto and ubuntu-base-22.04.1-r0.cortexa53_crypto
ERROR: Logfile of failure stored in: /home/builder1/work/fsl-auto-yocto-bsp/build_s32g274ardb2ubuntu/tmp/work/s32g274ardb2-fsl-linux/fsl-image-ubuntu/1.0-r0/temp/log.do_rootfs.2738097
ERROR: Task (/home/builder1/work/fsl-auto-yocto-bsp/sources/meta-alb/recipes-fsl/images/fsl-image-ubuntu.bb:do_rootfs) failed with exit code '1'
The issue was solved. Unfortunately, it appeared because of adding ldd and nfs-utils (as a habit from getting used to do that for a regular YOCTO style builds) to the local.conf which clashed with the ubuntu packages. Removing everything from the local.conf and leaving it empty from any add-ons solved the issue. So, I confirm that fsl-image-ubuntu-base and other fsl-image-ubuntu* are built successfully for the BSP#38.
Something happens in you host, it appears you missed some package to install, when running yocto make sure you have all the packages and erase everything yocto did before building again,
https://docs.yoctoproject.org/
Hello, Bio
I have check my packages on my host, they are all match the requirements mentioned in the yocto document:
yocto required:
Git 1.8.3.1 or greater
tar 1.28 or greater
Python 3.8.0 or greater
GNU make 4.0 or greater
mine:
And this was also done:
sudo apt install gawk wget git diffstat unzip texinfo gcc build-essential chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev python3-subunit mesa-common-dev zstd liblz4-tool file locales
But it still fail the same.
And the yocto poky demo: https://docs.yoctoproject.org/brief-yoctoprojectqs/index.html can be build successfully on my host.
Best regards!
May I know How to fix this error?
I'm wondering the same. Would appreciate. Please see our log as one the replies above.
