Hi Team,
We need the average use case power consumption of S32G378ASAK1VUCR and S32G399ASCK1VUCR for derating analysis purpose.
The numbers provided in S32G datasheet for maximum and thermal use cases seems to be of at a higher end. Is there any other normal use case number that we can refer for analysis purpose alone?.
This query is only for 0.8V supplied by the PF5300 regulator.
