S32DS compile IPCF_FreeRTOS_S32G274A_M7_0
piaochunri
When I build IPCF_FreeRTOS_S32G274A_M7_0,I found an error.How should I handle it.Thank you.
Daniel-Aguirre
Can you let us know which IPCF version are you using? Have you modified anything under the example project?
Under IPCF v4.9.0 we are able to compile the example no problem:
Out-of-the-box once we generated the required code under Config Tools.
Please, let us know.
Daniel-Aguirre
