S32DS Import example error
2,244 次查看
yuxuan
HI
When I want to import the IPCF 4.7 example, I encounter the following problems:
After I update the 3.5.1 update simulation software, I cannot import the IPCF 4.7 zip file.I don't know what the problem is. The RTD that IPCF depends on has been updated.
2,211 次查看
Daniel-Aguirre
Could you please tell us what version of S32 Design Studio are you using? Have you verified on the IPCF v4.7 release notes that it is compatible with your S32DS version?
At this moment, the official public release for IPCF is v4.6, which is compatible with S32DS v3.4. It seems you were given an Alpha customer access to non-public releases.
If this does not solve your problem, please help us contacting your local NXP representative, for them to redirect your inquiry through their respective channels.
Please, let us know.
2,212 次查看
Daniel-Aguirre
2,201 次查看
yuxuan
My S32 Design Studio version is V3.5.1. I successfully imported the IPCF 4.8 example. Thank you for your valuable answer
