S32 Design Studio v3.6.1 crashes
1,398 次查看
pcentauri92
Hi NXP Community,
I am working with a fresh install of S32 Design studio v3.6.1 and created a project for S32G399A. I have also intsalled the RTD package using the "Install new Software option". When I try to access the IVT tools, the design studio crashes abruptly and it happens every time I do that. I have tried installing a previous release from March 31, 2025 which also has the same problem.
I am attaching the error log generated by the studio here.
My OS info:
Linux precision-3591 6.8.0-59-generic #61~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Tue Apr 15 17:03:15 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
Java version:
openjdk 21.0.7 2025-04-15
OpenJDK Runtime Environment (build 21.0.7+6-Ubuntu-0ubuntu122.04)
OpenJDK 64-Bit Server VM (build 21.0.7+6-Ubuntu-0ubuntu122.04, mixed mode, sharing)
Could you please help me out with a fix for this issue? Let me know if you need any other information from my end.
Thanks.
标记 (2)
5 回复数
1,294 次查看
chenyin_h
Hello, @pcentauri92
Thanks for you reply.
I have checked the log you provided, it may caused by the incompatible version of JAVA, from the release notes, Java17 is recommended.
However, with further checking on the issue, I suggest not using S32DS under Linux, it is because currently, there are issues existed on supporting RTD on Ubuntu host. As a result, make the installation issue fixed would not help on further use of RTD. I suggest installing the S32DS3.6.1 on a Windows Host.
Sorry for your inconvenience.
Chenyin
1,383 次查看
chenyin_h
Hello, @pcentauri92
Thanks for the post.
From the release notes of S32DS3.6.1, the following OS are supported for S32DS3.6.1, I suggest trying installing it on the OS supported for another trial.
Chenyin
1,370 次查看
pcentauri92
Hi @chenyin_h ,
I have updated my OS to the latest version which is compatible with S32 Design studio v3.6.1 and the issue still exists as you can see below.
898 次查看
daniel_ll
hi @pcentauri92 . Where you able to solve this issue?
Question: Are you using Wayland or X11 in your Ubuntu setup?
396 次查看
pcentauri92
Hi @daniel_ll ,
My distribution comes with X11 by default and I have been able to use the design studio by setting the GDK_BACKEND environment variable.
export GDK_BACKEND=x11
However, fthe issu still exists without the use of that variable.  My distribution version is as shown below
PRETTY_NAME="Ubuntu 24.04.2 LTS"
NAME="Ubuntu"
VERSION_ID="24.04"
VERSION="24.04.2 LTS (Noble Numbat)"
VERSION_CODENAME=noble
ID=ubuntu
Has a fix been released for this in the newer version of ubuntu (25.10) ?
%3CLINGO-SUB%20id%3D%22lingo-sub-2107712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32%20Design%20Studio%20v3.6.1%20%E5%B4%A9%E6%BA%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2107712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%E4%BA%86%20S32%20Design%20studio%20v3.6.1%EF%BC%8C%E5%B9%B6%E4%B8%BA%20S32G399A%20%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E3%80%82%E6%88%91%E8%BF%98%E4%BD%BF%E7%94%A8%20%22%20%E5%AE%89%E8%A3%85%E6%96%B0%E8%BD%AF%E4%BB%B6%E9%80%89%E9%A1%B9%20%22%20%E5%AE%89%E8%A3%85%E4%BA%86%20RTD%20%E4%BB%A3%E7%A0%81%E5%8C%85%E3%80%82%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%AE%BF%E9%97%AE%20IVT%20%E5%B7%A5%E5%85%B7%E6%97%B6%EF%BC%8C%E8%AE%BE%E8%AE%A1%E5%B7%A5%E4%BD%9C%E5%AE%A4%E4%BC%9A%E7%AA%81%E7%84%B6%E5%B4%A9%E6%BA%83%EF%BC%8C%E8%80%8C%E4%B8%94%E6%AF%8F%E6%AC%A1%E9%83%BD%E8%BF%99%E6%A0%B7%E3%80%82%E6%88%91%E6%9B%BE%E5%B0%9D%E8%AF%95%E5%AE%89%E8%A3%852025%E5%B9%B43%E6%9C%8831%E6%97%A5%E7%9A%84%E5%85%88%E5%89%8D%E7%89%88%E6%9C%AC%EF%BC%8C%E4%BD%86%E4%B9%9F%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%AD%A4%E9%99%84%E4%B8%8A%E5%B7%A5%E4%BD%9C%E5%AE%A4%E7%94%9F%E6%88%90%E7%9A%84%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%BF%A1%E6%81%AF%EF%BC%9A%3CBR%20%2F%3ELinux%20precision-3591%206.8.0-59-generic%20%2361~22.04.1-UbuntuSMP%20PREEMPT_DYNAMIC%20Tue%20Apr%2015%2017%3A03%3A15%20UTC%202%20x86_64%20x86_64%20x86_64%20GNU%2FLinux%3C%2FP%3E%3CP%3EJava%20%E7%89%88%E6%9C%AC%EF%BC%9A%3CBR%20%2F%3Eopenjdk%2021.0.7%202025-04-15%20OpenJDK%20%E8%BF%90%E8%A1%8C%E6%97%B6%E7%8E%AF%E5%A2%83%EF%BC%88%E5%86%85%E9%83%A8%E7%89%88%E6%9C%AC%2021.0.7%2B6-Ubuntu-0Ubuntu122.04%EF%BC%89%3CBR%20%2F%3EOpenJDK%2064%20%E4%BD%8D%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%99%9A%E6%8B%9F%E6%9C%BA%EF%BC%88%E6%9E%84%E5%BB%BA%2021.0.7%2B6-Ubuntu-0Ubuntu122.04%EF%BC%8C%E6%B7%B7%E5%90%88%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%85%B1%E4%BA%AB%EF%BC%89%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E6%88%91%E6%8F%90%E4%BE%9B%E5%85%B6%E4%BB%96%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20Design%20Studio%20v3.6.1%20crashes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188280%22%20target%3D%22_blank%22%3E%40daniel_ll%3C%2FA%3E%2C%3CBR%20%2F%3E%E6%88%91%E7%9A%84%E5%8F%91%E8%A1%8C%E7%89%88%E9%BB%98%E8%AE%A4%E5%B8%A6%E6%9C%89%20X11%EF%BC%8C%E9%80%9A%E8%BF%87%E8%AE%BE%E7%BD%AE%20GDK_BACKEND%20%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%AE%BE%E8%AE%A1%E5%B7%A5%E4%BD%9C%E5%AE%A4%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3Eexport%20GDK_BACKEND%3Dx11%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E4%BD%BF%E7%94%A8%E8%AF%A5%E5%8F%98%E9%87%8F%EF%BC%8C%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%20%E6%88%91%E7%9A%84%E5%8F%91%E8%A1%8C%E7%89%88%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%3CBR%20%2F%3E%3CBR%20%2F%3EPRETTY_NAME%3D%22Ubuntu%2024.04.2LTS%20%22%20%3CBR%20%2F%3E%20NAME%3D%20%22%20Ubuntu%20%22%20%3CBR%20%2F%3E%20VERSION_ID%3D%20%22%2024.04%20%22%20VERSI%20%3CBR%20%2F%3E%20ON%3D%20%22%2024.04.2%20LTS%20(Noble%20Numbat)%20%22%20version%20%3CBR%20%2F%3E%20_codename%3DNoble%20%3CBR%20%2F%3E%20id%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3DUbuntu%20%E5%9C%A8%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20ubuntu%20(25.10)%20%E4%B8%AD%E6%98%AF%E5%90%A6%E5%8F%91%E5%B8%83%E4%BA%86%E9%92%88%E5%AF%B9%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E4%BF%AE%E5%A4%8D%E7%A8%8B%E5%BA%8F%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20Design%20Studio%20v3.6.1%20crashes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F250739%22%20target%3D%22_blank%22%3E%40pcentauri92%3C%2FA%3E%E3%80%82%E4%BD%A0%E4%BB%AC%E8%83%BD%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%97%AE%E9%A2%98%E6%82%A8%E5%9C%A8%20Ubuntu%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20Wayland%20%E8%BF%98%E6%98%AF%20X11%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2109036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20Design%20Studio%20v3.6.1%20crashes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2109036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F250739%22%20target%3D%22_blank%22%3E%40pcentauri92%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%A3%80%E6%9F%A5%E4%BA%86%E4%BD%A0%E6%8F%90%E4%BE%9B%E7%9A%84%E6%97%A5%E5%BF%97%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E6%98%AF%E7%94%B1%E4%B8%8D%E5%85%BC%E5%AE%B9%E7%9A%84%20JAVA%20%E7%89%88%E6%9C%AC%E9%80%A0%E6%88%90%E7%9A%84%EF%BC%8C%E4%BB%8E%E5%8F%91%E8%A1%8C%E8%AF%B4%E6%98%8E%E6%9D%A5%E7%9C%8B%EF%BC%8C%E6%8E%A8%E8%8D%90%E4%BD%BF%E7%94%A8%20%3CSPAN%20class%3D%22fontstyle0%22%3EJava17%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E7%BB%8F%E8%BF%87%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%A3%80%E6%9F%A5%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%B8%8D%E8%A6%81%E5%9C%A8%20Linux%20%E4%B8%8B%E4%BD%BF%E7%94%A8%20S32DS%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%9B%AE%E5%89%8D%E5%9C%A8%3CSPAN%3EUbuntu%20%E4%B8%BB%E6%9C%BA%E4%B8%8A%3C%2FSPAN%3E%E5%AD%98%E5%9C%A8%E6%94%AF%E6%8C%81RTD%20%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E4%BF%AE%E5%A4%8D%E5%AE%89%E8%A3%85%E9%97%AE%E9%A2%98%E6%97%A0%E5%8A%A9%E4%BA%8E%E8%BF%9B%E4%B8%80%E6%AD%A5%E4%BD%BF%E7%94%A8%20RTD%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E5%9C%A8%20Windows%20%E4%B8%BB%E6%9C%BA%E4%B8%8A%E5%AE%89%E8%A3%85%20S32DS3.6.1%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E7%BB%99%E6%82%A8%E5%B8%A6%E6%9D%A5%E4%B8%8D%E4%BE%BF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%88%87%E5%AE%81%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2108045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20Design%20Studio%20v3.6.1%20crashes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2108045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E5%B0%86%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E6%9B%B4%E6%96%B0%E5%88%B0%E4%B8%8E%20S32%20Design%20studio%20v3.6.1%20%E5%85%BC%E5%AE%B9%E7%9A%84%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pcentauri92_0-1748608705113.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pcentauri92_0-1748608705113.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F340704iF2FBAB5D54F09FA6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pcentauri92_0-1748608705113.png%22%20alt%3D%22pcentauri92_0-1748608705113.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2107975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32%20Design%20Studio%20v3.6.1%20crashes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2107975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F250739%22%20target%3D%22_blank%22%3E%40pcentauri92%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%8E%20S32DS3.6.1%20%E7%9A%84%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%E4%B8%AD%EF%BC%8CS32DS3.6.1%20%E6%94%AF%E6%8C%81%E4%BB%A5%E4%B8%8B%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E5%B0%9D%E8%AF%95%E5%9C%A8%E6%94%AF%E6%8C%81%E7%9A%84%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%E5%AE%89%E8%A3%85%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%86%8D%E6%AC%A1%E8%AF%95%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1748599721636.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1748599721636.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F340688iAA9DEEB27008C91B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1748599721636.png%22%20alt%3D%22chenyin_h_0-1748599721636.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
