Random shutdowns due to watchdogs
bgarcia
I am using BSP37.0 and I can observe random reboots in the Linux instance.
[␛[0;32m  OK  ␛[0m] Started ␛[0;1;39mSerial Getty on ttyLF0␛[0m.
[␛[0;32m  OK  ␛[0m] Reached target ␛[0;1;39mLogin Prompts␛[0m.
[␛[0;32m  OK  ␛[0m] Reached target ␛[0;1;39mMulti-User System␛[0m.
         Starting ␛[0;1;39mRecord Runlevel Change in UTMP␛[0m...
[␛[0;32m  OK  ␛[0m] Finished ␛[0;1;39mRecord Runlevel Change in UTMP␛[0m.
Auto Linux BSP 37.0 s32g274ardb2 ttyLF0
s32g274ardb2 login:          Stopping ␛[0;1;39mSession c4 of User root␛[0m...
[␛[0;32m  OK  ␛[0m] Removed slice ␛[0;1;39mSlice /system/modprobe␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mMulti-User System␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mLogin Prompts␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mRPC Port Mapper␛[0m.
[␛[0;32m  OK          Stopping ␛[0;1;39mSerial Getty on ttyLF0␛[0m...
         Stopping ␛[0;1;39mOpenSSH Per-Conne…Daemon (192.168.0.96:45432)␛[0m...
         Stopping ␛[0;1;39mSystem Logging Service␛[0m...
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mResets System Activity Logs␛[0m.
         Stopping ␛[0;1;39mLoad/Save Random Seed␛[0m...
         Stopping ␛[0;1;39mXinetd A Powerful Replacement For Inetd␛[0m...
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mJob spooling tools␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mPeriodic Command Scheduler␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mirqbalance daemon␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mSystem level shared mutex initializer␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mHardware RNG Entropy Gatherer Daemon␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mSystem Logging Service␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mNetperf Benchmark Server␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mNFS status monitor for NFSv2/3 locking.␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mRespond to IPv6 Node Information Queries␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mNetwork Router Discovery Daemon␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mXinetd A Powerful Replacement For Inetd␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mGetty on tty1␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mSerial Getty on ttyLF0␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mOpenSSH Per-Connec…n Daemon (192.168.0.96:45432)␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mLoad/Save Random Seed␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mSession c4 of User root␛[0m.
[␛[0;32m  OK  ␛[0m] Removed slice ␛[0;1;39mSlice /system/getty␛[0m.
[␛[0;32m  OK  ␛[0m] Removed slice ␛[0;1;39mSlice /system/serial-getty␛[0m.
[␛[0;32m  OK  ␛[0m] Removed slice ␛[0;1;39mSlice /system/sshd␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mHost and Network Name Lookups␛[0m.
         Stopping ␛[0;1;39mUser Login Management␛[0m...
         Stopping ␛[0;1;39mUser Manager for UID 0␛[0m...
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mOpenSSH Key Generation␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mUser Manager for UID 0␛[0m.
         Stopping ␛[0;1;39mUser Runtime Directory /run/user/0␛[0m...
[␛[0;32m  OK  ␛[0m] Unmounted ␛[0;1;39m/run/user/0␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mUser Runtime Directory /run/user/0␛[0m.
[␛[0;32m  OK  ␛[0m] Removed slice ␛[0;1;39mUser Slice of UID 0␛[0m.
         Stopping ␛[0;1;39mD-Bus System Message Bus␛[0m...
         Stopping ␛[0;1;39mPermit User Sessions␛[0m...
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mD-Bus System Message Bus␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mUser Login Management␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mPermit User Sessions␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mNetwork␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mRemote File Systems␛[0m.
         Stopping ␛[0;1;39mNetwork Name Resolution␛[0m...
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mNetwork Name Resolution␛[0m.
         Stopping ␛[0;1;39mNetwork Configuration␛[0m...
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mNetwork Configuration␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mPreparation for Network␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mIPv6 Packet Filtering Framework␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mIPv4 Packet Filtering Framework␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mBasic System␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mPath Units␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mDispatch Password …ts to Console Directory Watch␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mForward Password R…uests to Wall Directory Watch␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mSlice Units␛[0m.
[␛[0;32m  OK  ␛[0m] Removed slice ␛[0;1;39mUser and Session Slice␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mSocket Units␛[0m.
[␛[0;32m  OK  ␛[0m] Closed ␛[0;1;39mD-Bus System Message Bus Socket␛[0m.
[␛[0;32m  OK  ␛[0m] Closed ␛[0;1;39msshd.socket␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mSystem Initialization␛[0m.
[␛[0;32m  OK  ␛[0m] Closed ␛[0;1;39mSyslog Socket␛[0m.
[␛[0;32m  OK  ␛[0m] Closed ␛[0;1;39mNetwork Service Netlink Socket␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mApply Kernel Variables␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mLoad Kernel Modules␛[0m.
         Stopping ␛[0;1;39mNetwork Time Synchronization␛[0m...
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mNetwork Time Synchronization␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mCreate Volatile Files and Directories␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mLocal File Systems␛[0m.
         Unmounting ␛[0;1;39m/tmp␛[0m...
         Unmounting ␛[0;1;39m/var/volatile/tmp␛[0m...
[␛[0;32m  OK  ␛[0m] Unmounted ␛[0;1;39m/tmp␛[0m.
[␛[0;32m  OK  ␛[0m] Unmounted ␛[0;1;39m/var/volatile/tmp␛[0m.
         Unmounting ␛[0;1;39m/var/volatile␛[0m...
[␛[0;32m  OK  ␛[0m] Unmounted ␛[0;1;39m/var/volatile␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mPreparation for Local File Systems␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped target ␛[0;1;39mSwaps␛[0m.
[␛[0;32m  OK  ␛[0m] Reached target ␛[0;1;39mUnmount All Filesystems␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mRemount Root and Kernel File Systems␛[0m.
[␛[0;32m  OK  ␛[0m] Stopped ␛[0;1;39mCreate Static Device Nodes in /dev␛[0m.
[␛[0;32m  OK  ␛[0m] Reached target ␛[0;1;39mSystem Shutdown␛[0m.
[␛[0;32m  OK  ␛[0m] Reached target ␛[0;1;39mLate Shutdown Services␛[0m.
[␛[0;32m  OK  ␛[0m] Finished ␛[0;1;39mSystem Reboot␛[0m.
[␛[0;32m  OK  ␛[0m] Reached target ␛[0;1;39mSystem Reboot␛[0m.
[44710.450861] systemd-shutdown[1]: Using hardware watchdog 's32cc watchdog', version 0, device /dev/watchdog0
[44710.450900] systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument
[44710.479157] systemd-shutdown[1]: Syncing filesystems and block devices.
[44710.495131] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[44710.508589] systemd-journald[123]: Received SIGTERM from PID 1 (systemd-shutdow).
[44710.527190] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[44710.537177] systemd-shutdown[1]: Unmounting file systems.
[44710.539229] [983]: Remounting '/' read-only with options 'n/a'.
[44710.548239] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: disabled.
[44710.557310] systemd-shutdown[1]: All filesystems unmounted.
[44710.557327] systemd-shutdown[1]: Deactivating swaps.
[44710.557415] systemd-shutdown[1]: All swaps deactivated.
[44710.557425] systemd-shutdown[1]: Detaching loop devices.
[44710.557828] systemd-shutdown[1]: All loop devices detached.
[44710.557838] systemd-shutdown[1]: Stopping MD devices.
[44710.558070] systemd-shutdown[1]: All MD devices stopped.
[44710.558083] systemd-shutdown[1]: Detaching DM devices.
[44710.558290] systemd-shutdown[1]: All DM devices detached.
[44710.558301] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
[44710.631657] systemd-shutdown[1]: Syncing filesystems and block devices.
[44710.632795] systemd-shutdown[1]: Rebooting.
[44710.638199] pfeng 46000000.pfe: Suspending driver
[44710.638578] pfeng 46000000.pfe pfe0: Link is Down
[44710.639183] pfeng 46000000.pfe pfe1: Link is Down
[44710.652541] pfeng 46000000.pfe: HIF3 not enabled, skipped
[44710.652553] pfeng 46000000.pfe: HIF2 stopped
[44710.683929] pfeng 46000000.pfe: HIF2 disabled
[44710.683942] pfeng 46000000.pfe: HIF1 stopped
[44710.707884] pfeng 46000000.pfe: HIF1 disabled
[44710.707895] pfeng 46000000.pfe: HIF0 stopped
[44710.727888] pfeng 46000000.pfe: HIF0 disabled
[44710.743690] pfeng 46000000.pfe: Global poller finished
[44710.743769] pfeng 46000000.pfe: Removing default logical interface (pfe0, parent: emac0)
[44710.743832] pfeng 46000000.pfe: pfe0 (p0x0000000018e0081e) removed from emac0 (p0x00000000a9506e0f)
[44710.743994] pfeng 46000000.pfe: Removing default logical interface (hif0-logif, parent: hif0)
[44710.744053] pfeng 46000000.pfe: hif0-logif (p0x000000000c7d2183) removed from hif0 (p0x000000002a3af9db)
[44710.744211] pfeng 46000000.pfe: Removing default logical interface (pfe1, parent: emac1)
[44710.744270] pfeng 46000000.pfe: pfe1 (p0x00000000b45034b6) removed from emac1 (p0x00000000cec7b85d)
[44710.744426] pfeng 46000000.pfe: Removing default logical interface (hif1-logif, parent: hif1)
[44710.744483] pfeng 46000000.pfe: hif1-logif (p0x000000005584197e) removed from hif1 (p0x0000000065459d60)
[44710.744642] pfeng 46000000.pfe: Removing default logical interface (pfe2, parent: emac2)
[44710.744699] pfeng 46000000.pfe: pfe2 (p0x0000000075ebd0eb) removed from emac2 (p0x000000002b20084b)
[44710.744855] pfeng 46000000.pfe: Removing default logical interface (hif2-logif, parent: hif2)
[44710.744914] pfeng 46000000.pfe: hif2-logif (p0x000000008aac08b9) removed from hif2 (p0x000000001f3b440d)
[44711.452216] pfeng 46000000.pfe: Stopping rtable worker...
[44711.452311] pfeng 46000000.pfe: rtable worker stopped
[44711.452804] pfeng 46000000.pfe: PFE Platform stopped
[44711.452907] pfeng 46000000.pfe: PFE controller off
[44711.453184] ci_hdrc ci_hdrc.0: remove, state 4
[44711.453199] usb usb1: USB disconnect, device number 1
[44711.453890] ci_hdrc ci_hdrc.0: USB bus 1 deregistered
[44711.563946] sja1110 spi5.0: [sja1110_remove]
[44711.564123] sja1110 spi5.1: [sja1110_remove]
[44711.564925] s32cc-wdt 4010c000.watchdog: Device shutdown: Expect reboot!
[44711.565047] reboot: Restarting system
[44711.565053] printk: enabled sync mode
[44711.567669] printk: console [ttyLF0]: printing thread stopped
NOTICE:  Reset status: Destructive Reset (RUN)
NOTICE:  BL2: v2.5(release):bsp37.0-2.5
NOTICE:  BL2: Built : 09:12:21, Jun 13 2023
NOTICE:  BL2: Booting BL31
U-Boot 2020.04+g8f2fa84f9e (Jan 16 2024 - 15:34:46 +0000)
As you can see, this happened at boot time 44710. Looks like the watchdog not being able to be feeded is the root cause
Are you aware of this?
Daniel-Aguirre
Are you using any NXP reference boards? Or is this a custom board?
Was this BSP built by you? Or did you take the pre-built BSP provided by NXP (under a *.tgz file)?
From our side, we don't see the behavior you are seeing, we can successfully boot our RDB2 with BSP37.0.
Please, let us know.
