[Question] S32 flash tool respone error workaround.
ljy
We made a new board based on S32G274ARDB2 Board.
I tried to write the program using the S32 flash GUI tool, but a response error occurred as shown below.
Since u-boot & kernel prompt was used normally by SD-Card booting, UART communication seems to be no problem, and the switch setting is also in progress normally.
