QSPI Access in U-boot BSP 38
3,050 次查看
nkv2
Hello Nxp Team,
We are working on a Custom board with S32G2 based on S32G2xxaevb. We have QSPI Norflash of Micron mt35xu01gbba. We could successfully boot the board with qspi-uboot in BSP31. But after migrating to 38, we could able to boot the board with ATF and atf is booting u-boot as well. But u-boot could not able to access the Nor flash and read or write the environment settings. We have tried changing multiple settings but could not able to succeed in communicating with the QSPI.
Below i have attached the verifclk, dm tree and u-boot print out for your reference. Please let us know how can we resolve this issue and access the QSPI. Please let us know if you need any more details.
thank you in advance.
标记 (5)
3,008 次查看
nkv2
After updating the clocks and removing the unused chip select pin the device tree helped to resolve this issue.
3,009 次查看
nkv2
