PFE not initialised
PFE not initialised
2,444 次查看
Youngsoo_do
We are using S32G_VNP_RDB3 (S32G399A).
We integrated the project using the distributed firmware and drivers and Tresos.
However, in the Eth_43_PFE_PreInit and Eth_43_PFE_Init functions, I get ETH_STATE_UNINIT, which does not initialize.
I don't know what to fix, and there are no compilation errors.
I'm sharing the code to share the problem with people who are having similar difficulties as me.
If anyone knows of a solution, please share.
标记 (1)
2,362 次查看
Daniel-Aguirre
Thanks for your feedback. That is correct. There is a readme.txt file available under the example_application folder for the PFE-MCAL package which provides more information on regards of usage and compilation.
Please, let us know.
5 回复数
2,410 次查看
Daniel-Aguirre
Can you let us know which PFE-FW/PFE-MCAL/RTD version are you using? Are you using any NXP example?
2,408 次查看
Youngsoo_do
Thank you so much for your response. I'm using the following version
  PFE-FW_S32G_1.7.1
  PFE_Firmware_1_7_1
  PFE-DRV_S32G_M7_MCAL_1.2.0
  SW32G_RTD_4.4_4.0.2
The project I posted was created by piecing together the header file from the PFE example program.
Today, I realized I must compile the makefile to generate the S32G Studio project.
However, I'm having trouble with the makefile. Could you please help me with this question?
https://community.nxp.com/t5/S32G/makefile-error-in-PFE-example/m-p/1876417#M7056
2,402 次查看
Daniel-Aguirre
For the information being provided, we understand that you are not using the NXP example itself, is this correct?
Are you able to compile/run the NXP example without modifications?
2,395 次查看
Youngsoo_do
Hi!
among the PFE examples,
PFE-DRV_S32G_M7_MCAL_1.2.0\example_application\MasterProject_RDB3
The examples in this folder will perform "Generate project" as normal in Tresos.
However, I recently realized that I need to use a Makefile.
标记 (1)
2,363 次查看
Daniel-Aguirre
%3CLINGO-SUB%20id%3D%22lingo-sub-1875641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPFE%20%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1875641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8S32G_VNP_RDB3%EF%BC%88S32G399A%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E5%88%86%E5%B8%83%E5%BC%8F%E5%9B%BA%E4%BB%B6%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BB%A5%E5%8F%8A%20Tresos%20%E9%9B%86%E6%88%90%E4%BA%86%E8%AF%A5%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%20Eth_43_PFE_PreInit%20%E5%92%8C%20Eth_43_PFE_Init%20%E5%87%BD%E6%95%B0%E4%B8%AD%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%20ETH_STATE_UNINIT%EF%BC%8C%E5%AE%83%E6%B2%A1%E6%9C%89%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E8%AF%A5%E4%BF%AE%E5%A4%8D%E4%BB%80%E4%B9%88%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%B2%A1%E6%9C%89%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%88%86%E4%BA%AB%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%B8%8E%E9%81%87%E5%88%B0%E4%B8%8E%E6%88%91%E7%B1%BB%E4%BC%BC%E5%9B%B0%E9%9A%BE%E7%9A%84%E4%BA%BA%E5%88%86%E4%BA%AB%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E8%AF%B7%E5%88%86%E4%BA%AB%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
