PFE Master/Slave - Set up M7 Master Network
ソリューションへジャンプ
4,456件の閲覧回数
GuilhermeS32G
Dear NXP fellows,
This question is a sequel to my previous topic:
Questions regarding multi-core networking in S32G399A
Right now, I have enabled PFE Master/Slave on our custom board based on S32G399A-RDB3 by appending pfe-slave to the Yocto distro-features:
DISTRO_FEATURES:append = " pfe pfe-slave"
This enables the PFE Slave to run on the A53 cores (Linux BSP).
On the slave side, it seems to be working as expected, I can assign IP addresses to the three PFE interfaces and the ping is working from both sides.
For your reference, the command libfci_cli phyif-print returns:
DISCLAIMER: This is a DEMO application. It is not part of the production code deliverables.
 0: emac0
      <ENABLED>
      <promisc:OFF, mode:DEFAULT, block-state:NORMAL>
      <vlan-conf:OFF, ptp-conf:OFF, ptp-promisc:OFF, q-in-q:ON>
      <discard-if-ttl-below-2:OFF, fast-forward-all-tcp:ON>
      ingress: 57 egress: 45 discarded: 0 malformed: 0
      flexible-filter: ---
      ptp-mgmt-if: ---
      MAC:
          00:04:9f:be:ef:00
          33:33:00:00:00:01
          01:00:5e:00:00:01
          33:33:ff:be:ef:00
          01:80:c2:00:00:00
          01:80:c2:00:00:03
          01:80:c2:00:00:0e
          33:33:00:01:00:03
          01:00:5e:00:00:fc
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       0: emac0
            <ENABLED>
            <promisc:ON, match-mode:AND, discard-on-match:OFF>
            accepted: 57 rejected: 0 discarded: 0 processed: 57
            egress: hif0
            match-rules: ---
 1: emac1
      <ENABLED>
      ingress: 75 egress: 53 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC:
          00:04:9f:be:ef:01
          33:33:00:00:00:01
          01:00:5e:00:00:01
          33:33:ff:be:ef:01
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       1: emac1
            <ENABLED>
            accepted: 75 rejected: 0 discarded: 0 processed: 75
            egress: hif1
            match-rules: ---
 2: emac2
      <ENABLED>
      ingress: 13 egress: 37 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC:
          00:04:9f:be:ef:02
          33:33:00:00:00:01
          01:00:5e:00:00:01
          33:33:ff:be:ef:02
          01:80:c2:00:00:00
          01:80:c2:00:00:03
          01:80:c2:00:00:0e
          01:00:5e:00:00:fc
          33:33:00:01:00:03
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       2: emac2
            <ENABLED>
            accepted: 13 rejected: 0 discarded: 0 processed: 13
            egress: hif2
            match-rules: ---
 5: util
      <DISABLED>
      ingress: 0 egress: 0 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC: ---
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces: ---
 6: hif0
      <ENABLED>
      ingress: 105 egress: 57 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC: ---
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       3: hif0
            <ENABLED>
            accepted: 29 rejected: 0 discarded: 0 processed: 29
            egress: ---
            match-rules: ---
 7: hif1
      <ENABLED>
      ingress: 53 egress: 75 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC: ---
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       4: hif1
            <ENABLED>
            accepted: 0 rejected: 0 discarded: 0 processed: 0
            egress: ---
            match-rules: ---
 8: hif2
      <ENABLED>
      ingress: 37 egress: 13 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC: ---
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       5: hif2
            <ENABLED>
            egress: ---
            match-rules: ---
 9: hif3
      <DISABLED>
      ingress: 0 egress: 0 discarded: 31 malformed: 0
      ptp-mgmt-if: ---
      MAC: ---
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       6: hif3
            <ENABLED>
            egress: ---
            match-rules: ---
Command successfully executed.
 and the command libfci_cli logif-print returns:
 0: emac0
      <ENABLED>
      parent: emac0
      egress: hif0
      match-rules: ---
 1: emac1
      <ENABLED>
      parent: emac1
      egress: hif1
      match-rules: ---
 2: emac2
      <ENABLED>
      parent: emac2
      egress: hif2
      match-rules: ---
 3: hif0
      <ENABLED>
      parent: hif0
      egress: ---
      match-rules: ---
 4: hif1
      <ENABLED>
      parent: hif1
      egress: ---
      match-rules: ---
 5: hif2
      <ENABLED>
      parent: hif2
      egress: ---
      match-rules: ---
 6: hif3
      <ENABLED>
      parent: hif3
      egress: ---
      match-rules: ---
However, I would like to configure the M7 core PFE-master now.
My questions are:
  • Can I assign an IP address to the PFE Master from the PFE Slave (BSP)?
  • Do I need to use the EB Tresos PFE-DRV_S32G_M7_MCAL sample application for configuring the M7 core networking?
  • Does it require to connect the S32G Debug Probe to the board in order to access the M7 core?
Thank you for your support!
Guilherme
4,418件の閲覧回数
Joey_z
hi,GuilhermeS32G
To configure PFE-master for M7 core, you can refer to the PFE-DRV_S32G_M7_MCAL package MasterProject_RDB3 project. In the meantime, you can refer to the readme for more details to complete the setup. You can set IP_ADDRESS_CTRL_0 to set the IP address . RTD drivers must be installed, copy the installed RTD driver plugins and PFE driver plugin to Tresos plugins directory. Also, Run and debug the application with Lauterbach TRACE32.
Joey
6 返答(返信)
4,419件の閲覧回数
Joey_z
hi,GuilhermeS32G
Joey
4,414件の閲覧回数
GuilhermeS32G
Hello @Joey_z ,
Thank you for your reply.
I see, so that means I require the Lauterbach Trace32 debugger and the EB Tresos Studio IDE for successfully running this example.
Do you know if there is any movement inside NXP to migrate the PFE-DRV_S32G_M7_MCAL software to the S32 Design Studio IDE and supporting the S32 Debug Probe instead?
Guilherme
4,405件の閲覧回数
Joey_z
hi,GuilhermeS32G
It is recommended that you debug using Lauterbach Trace32 according to readme.txt requirements. The S32 Debug Probe can be debuggable by loading .elf files, but this is  unstable and does not ensure that you can debug successfully, you can see the following way.
If the following problems occur, try loading the main.c file.
Joey
4,400件の閲覧回数
GuilhermeS32G
Hello @Joey_z ,
Thank you for your explanation.
I can see that the latest releases of the S32G Real-Time Driver AUTOSAR 4.4 for Cortex-M7 can be configured, built, and debugged using the S32 Design Studio. However, the S32G PFE MCAL 4.4 driver still requires EB Tresos Studio.
Is there any work in progress to make the future releases of the S32G PFE MCAL driver compatible with the S32 Design Studio?
Thanks again.
Guilherme
4,398件の閲覧回数
Joey_z
hi,GuilhermeS32G
PFE MCAL driver does not have this function, thank you for your suggestion, I will report this problem.
Joey
4,393件の閲覧回数
GuilhermeS32G
Hello @Joey_z ,
Ok, thank you very much.
Guilherme
%3CLINGO-SUB%20id%3D%22lingo-sub-1986630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPFE%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20-%20M7%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1986630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%83%95%E3%82%A7%E3%83%AD%E3%83%BC%E3%81%AE%E7%9A%86%E6%A7%98%E3%81%B8%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AE%E5%89%8D%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AE%E7%B6%9A%E7%B7%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G%2FQuestions-regarding-multi-core-networking-in-S32G399A%2Fm-p%2F1973875%2Fhighlight%2Ftrue%23M11229%22%20target%3D%22_self%22%3ES32G399A%20%E3%81%AE%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81S32G399A-RDB3%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7PFE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%80%81Yocto%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E6%A9%9F%E8%83%BD%E3%81%ABpfe-slave%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EDISTRO_FEATURES%3Aappend%20%3D%20%22%20pfe%20pfe-slave%22%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81PFE%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%82%92%20A53%20%E3%82%B3%E3%82%A2%20(Linux%20BSP)%20%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%80%813%E3%81%A4%E3%81%AEPFE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%ABIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81ping%E3%81%AF%E4%B8%A1%E5%81%B4%E3%81%8B%E3%82%89%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%20%3CEM%3Ephyif-print%20libfci_cli%3C%2FEM%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EDISCLAIMER%3A%20This%20is%20a%20DEMO%20application.%20It%20is%20not%20part%20of%20the%20production%20code%20deliverables.%0A%200%3A%20emac0%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%2057%20egress%3A%2045%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%0A%20%20%20%20%20%20%20%20%20%2000%3A04%3A9f%3Abe%3Aef%3A00%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3A00%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2001%3A00%3A5e%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3Aff%3Abe%3Aef%3A00%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A00%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A03%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A0e%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3A00%3A01%3A00%3A03%0A%20%20%20%20%20%20%20%20%20%2001%3A00%3A5e%3A00%3A00%3Afc%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%200%3A%20emac0%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%2057%20rejected%3A%200%20discarded%3A%200%20processed%3A%2057%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20hif0%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%201%3A%20emac1%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%2075%20egress%3A%2053%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%0A%20%20%20%20%20%20%20%20%20%2000%3A04%3A9f%3Abe%3Aef%3A01%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3A00%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2001%3A00%3A5e%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3Aff%3Abe%3Aef%3A01%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%201%3A%20emac1%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%2075%20rejected%3A%200%20discarded%3A%200%20processed%3A%2075%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20hif1%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%202%3A%20emac2%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%2013%20egress%3A%2037%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%0A%20%20%20%20%20%20%20%20%20%2000%3A04%3A9f%3Abe%3Aef%3A02%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3A00%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2001%3A00%3A5e%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3Aff%3Abe%3Aef%3A02%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A00%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A03%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A0e%0A%20%20%20%20%20%20%20%20%20%2001%3A00%3A5e%3A00%3A00%3Afc%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3A00%3A01%3A00%3A03%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%202%3A%20emac2%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%2013%20rejected%3A%200%20discarded%3A%200%20processed%3A%2013%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20hif2%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%205%3A%20util%0A%20%20%20%20%20%20%3CDISABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%200%20egress%3A%200%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%20---%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%20---%0A%206%3A%20hif0%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%20105%20egress%3A%2057%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%20---%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%203%3A%20hif0%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%2029%20rejected%3A%200%20discarded%3A%200%20processed%3A%2029%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%207%3A%20hif1%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%2053%20egress%3A%2075%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%20---%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%204%3A%20hif1%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%208%3A%20hif2%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%2037%20egress%3A%2013%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%20---%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%205%3A%20hif2%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%209%3A%20hif3%0A%20%20%20%20%20%20%3CDISABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%200%20egress%3A%200%20discarded%3A%2031%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%20---%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%206%3A%20hif3%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0ACommand%20successfully%20executed.%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FDISABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FDISABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CEM%3E%E3%81%BE%E3%81%9F%E3%80%81logif-print%20libfci_cli%3C%2FEM%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E5%80%A4%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EDISCLAIMER%3A%20This%20is%20a%20DEMO%20application.%20It%20is%20not%20part%20of%20the%20production%20code%20deliverables.%0A%200%3A%20emac0%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%2057%20rejected%3A%200%20discarded%3A%200%20processed%3A%2057%0A%20%20%20%20%20%20parent%3A%20emac0%0A%20%20%20%20%20%20egress%3A%20hif0%0A%20%20%20%20%20%20match-rules%3A%20---%0A%201%3A%20emac1%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%2075%20rejected%3A%200%20discarded%3A%200%20processed%3A%2075%0A%20%20%20%20%20%20parent%3A%20emac1%0A%20%20%20%20%20%20egress%3A%20hif1%0A%20%20%20%20%20%20match-rules%3A%20---%0A%202%3A%20emac2%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%2013%20rejected%3A%200%20discarded%3A%200%20processed%3A%2013%0A%20%20%20%20%20%20parent%3A%20emac2%0A%20%20%20%20%20%20egress%3A%20hif2%0A%20%20%20%20%20%20match-rules%3A%20---%0A%203%3A%20hif0%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%2029%20rejected%3A%200%20discarded%3A%200%20processed%3A%2029%0A%20%20%20%20%20%20parent%3A%20hif0%0A%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20match-rules%3A%20---%0A%204%3A%20hif1%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20parent%3A%20hif1%0A%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20match-rules%3A%20---%0A%205%3A%20hif2%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20parent%3A%20hif2%0A%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20match-rules%3A%20---%0A%206%3A%20hif3%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20parent%3A%20hif3%0A%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20match-rules%3A%20---%0ACommand%20successfully%20executed.%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%81%93%E3%81%A7M7%E3%82%B3%E3%82%A2PFE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3EPFE%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20(BSP)%20%E3%81%8B%E3%82%89%20PFE%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AB%20IP%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLI%3E%3CLI%3EM7%20%E3%82%B3%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%AF%E3%80%81EB%20Tresos%20PFE-DRV_S32G_M7_MCAL%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3EM7%20%E3%82%B3%E3%82%A2%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81S32G%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%E5%BF%9C%E6%8F%B4%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99!%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGuilherme%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1989997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APFE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20-%20M7%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%20%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGuilherme%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1989991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APFE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20-%20M7%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%3CSPAN%3EGuilhermeS32G%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EPFE%20MCAL%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AB%E3%81%AF%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8F%90%E6%A1%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%83%A7%E3%83%BC%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1989926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APFE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20-%20M7%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%20%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECortex-M7%E7%94%A8%E3%81%AES32G%20Real-Time%20Driver%20AUTOSAR%204.4%E3%81%AE%E6%9C%80%E6%96%B0%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%E3%80%81S32%20Design%20Studio%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81S32G%20PFE%20MCAL%204.4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E3%81%AF%E3%81%BE%E3%81%A0EB%20Tresos%20Studio%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ES32G%20PFE%20MCAL%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%B0%86%E6%9D%A5%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92S32%20Design%20Studio%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%92%E6%8C%81%E3%81%9F%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E9%80%B2%E8%A1%8C%E4%B8%AD%E3%81%AE%E4%BD%9C%E6%A5%AD%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGuilherme%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1989886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APFE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20-%20M7%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%3Ehi%2C%3CSPAN%3EGuilhermeS32G%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3Ereadme.txt%E8%A6%81%E4%BB%B6%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81Lauterbach%20Trace32%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82S32%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AF%E3%80%81.elf%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%A7%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E4%BF%9D%E8%A8%BC%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1730964157981.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1730964157981.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F309135i23D5919FEEFD2389%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1730964157981.png%22%20alt%3D%22Joey_z_0-1730964157981.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_1-1730964169114.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1730964169114.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F309137i23FA1A2B4DFB64EC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_1-1730964169114.png%22%20alt%3D%22Joey_z_1-1730964169114.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81main.c%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_2-1730964191889.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_2-1730964191889.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F309138i7F0C974F8AE0AC4C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_2-1730964191889.png%22%20alt%3D%22Joey_z_2-1730964191889.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%83%A7%E3%83%BC%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1988628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APFE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20-%20M7%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1988628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%20%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%AA%E3%82%8B%E3%81%BB%E3%81%A9%E3%80%81%E3%81%93%E3%81%AE%E4%BE%8B%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81Lauterbach%20Trace32%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%A8%20EB%20Tresos%20Studio%20IDE%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ENXP%E5%86%85%E3%81%A7PFE-DRV_S32G_M7_MCAL%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92S32%20Design%20Studio%20IDE%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%97%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%ABS32%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E5%8B%95%E3%81%8D%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EGuilherme%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1988593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3APFE%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20-%20M7%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1988593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%3CSPAN%3EGuilhermeS32G%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EM7%20%E3%82%B3%E3%82%A2%E3%81%AE%20PFE-master%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81PFE-DRV_S32G_M7_MCAL%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20MasterProject_RDB3%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AE%E9%96%93%E3%80%81%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81readme%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82IP_ADDRESS_CTRL_0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82RTD%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20RTD%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A8%20PFE%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%20Tresos%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81Lauterbach%20TRACE32%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1730879600804.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1730879600804.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F308870i8963C4831AB8EA96%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1730879600804.png%22%20alt%3D%22Joey_z_0-1730879600804.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_1-1730879608076.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1730879608076.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F308871iB28DDC1286F2372D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_1-1730879608076.png%22%20alt%3D%22Joey_z_1-1730879608076.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B8%E3%83%A7%E3%83%BC%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E
