Hello Team,
We have received NXP RDB3 board.
I tried to configure EEPROM for serial RCON using S32G Debug probe. Got below issue.
Selected CORE=M7_0
^Error:Core can't be stopped. State: None:CoreError(200) File "s32g3xx_i2c_RCON.py", line 265, in <module>
Note: Attached s32g3_eeprom.txt for complete log
Used S32G2 script for the same, as there is no difference with core initialization. Observed ACK is not received from slave.
Attached s32g3_eeprom_with_g2_script.txt for complete log.
Please consider this as high priority, as we need to test the same on our custom board, where only serial RCON is available.
