NXP S32g2 Board Ethernet or Jtag flash Rootfs
1,479 次查看
vimalrajendran
       Currently we are using our Custom NXP s32g274a board. Now we are Using S32 Flash tool via   Serial Flash mode for .scared image . but it has take long time. is there any other way to Quick flash method.
1,472 次查看
Bio_TICFSL
Hello vimalrajendran,
The S32 Flash tool takes times in programming more if it is high capacity memory, but I think your memory is not the problem it is the binary file, check is the binary file is appropriate size around 2.3GB.
1,454 次查看
vimalrajendran
Hi ,
        My <fsl-image-base-s32g274ardb2.sdcard > image file size 800mb. but it has take time around 3hours. Could you please give to me Ethernet Flash Steps. its may help full for me.
