GoldVIP Yocto build
GoldVIP Yocto build
1,424 次查看
MidhunSreenivas
We followed the steps for building Gold VIP Yocto image as mentioned in the user guide. But the build failed. Please refer the attached log and help us resolve it.
1 回复
1,401 次查看
gmocanu
Do you run the build in a restricted environment that doesn't have access to public registries? Do you have configured some private registries in your Docker configuration?
If possible, could you run the following commands (it's almost the same skopeo command referenced in the k3s recipe) and let us know what output you get:
$ bitbake k3s -c devshell
$ skopeo --debug --override-arch arm64 copy --additional-tag="docker.io/rancher/mirrored-pause:3.5" \
docker://rancher/mirrored-pause:3.5 docker-archive:mirrored-pause-test.tar
George
