Fetcher error while building the image after including pfe pfe-slave in local.conf.
481 次查看
hulk101
I want to build PFE multi-instance driver, For which I have added "DISTRO_FEATURES:append = " pfe"" in the local.conf, and while bitbake I get the below error:
WARNING: pfe-1.0.0-r0 do_fetch: Failed to fetch URL file://./s32g_pfe_class.fw, attempting MIRRORS if available
ERROR: pfe-1.0.0-r0 do_fetch: Fetcher failure: Unable to find file file://./s32g_pfe_class.fw anywhere. The paths that were searched were:
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe-1.0.0/fsl-auto
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe/fsl-auto
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/files/fsl-auto
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe-1.0.0/s32g274ardb2
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe/s32g274ardb2
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/files/s32g274ardb2
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe-1.0.0/s32cc
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe/s32cc
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/files/s32cc
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe-1.0.0/armv8a
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe/armv8a
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/files/armv8a
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe-1.0.0/aarch64
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe/aarch64
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/files/aarch64
/home/teuser/S32G2/fsl-auto-yocto-bsp/downloads
ERROR: pfe-1.0.0-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'file://./s32g_pfe_class.fw')
ERROR: Logfile of failure stored in: /home/teuser/S32G2/fsl-auto-yocto-bsp/build_s32g274ardb2/tmp/work/s32g274ardb2-fsl-linux/pfe/1.0.0-r0/temp/log.do_fetch.122939
ERROR: Task (/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe_1.0.0.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2128 tasks of which 2125 didn't need to be rerun and 1 failed.
标记 (1)
5 回复数
431 次查看
chenyin_h
Thanks for the reply, @hulk101
From the log, the PFE FW is not found by the Yocto, have you added it according to the UM?
Chenyin
429 次查看
hulk101
Hi, @chenyin_h
NXP_FIRMWARE_LOCAL_DIR is not added. I have searched for the "s32g_pfe_class.fw" file and was not able to find it. Should I create this file by my own ?
427 次查看
chenyin_h
Hello, @hulk101
Thanks for your reply.
No, the file mentioned is the PFE FW which is provisioned by NXP, you may download it in your account, like this:
Note that this is not the version used for BSP38, you may try downloading the 1.7.1 PFE FW for using with the BSP38.
I hope it will help.
Chenyin
449 次查看
chenyin_h
Hello, @hulk101
Thanks for the post.
May I know which version BSP is used?
Chenyin
443 次查看
hulk101
Hello @chenyin_h
BSP 38.0 version is used for the build.
Thankyou.
%3CLINGO-SUB%20id%3D%22lingo-sub-2171111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20local.conf%20%E4%B8%AD%E5%8A%A0%E5%85%A5%20pfe%20pfe-slave%20%E5%90%8E%EF%BC%8C%E5%9C%A8%E6%9E%84%E5%BB%BA%E9%95%9C%E5%83%8F%E6%97%B6%E5%87%BA%E7%8E%B0%20Fetcher%20%E9%94%99%E8%AF%AF%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%83%B3%E8%A6%81%E7%89%88%E6%9C%AC%20PFE%20%E5%A4%9A%E5%AE%9E%E4%BE%8B%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%B8%BA%E6%AD%A4%E6%88%91%E5%9C%A8%20local.conf%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%20%22%20distro_features%3A%20append%20%3D%20%22%20pfe%20%22%20%22%EF%BC%8C%E8%80%8C%E5%9C%A8%E6%AF%94%E7%89%B9%E7%83%98%E7%84%99%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%EF%BC%9Apfe-1.0.0-r0%20do_fetch%EF%BC%9AFailed%20to%20fetch%20URL%20file%3A%2F%2F.%2Fs32g_pfe_class.fw%E3%80%81%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%94%A8%EF%BC%8C%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20MIRRORS%3CBR%20%2F%3EERROR%3A%20pfe-1.0.0-r0%20do_fetch%EF%BC%9AFetcher%20failure%EF%BC%9A%E6%97%A0%E6%B3%95%E5%9C%A8%E4%BB%BB%E4%BD%95%E5%9C%B0%E6%96%B9%E6%89%BE%E5%88%B0%E6%96%87%E4%BB%B6%20file%3A%2F%2F.%2Fs32g_pfe_class.fw%E3%80%82%E6%90%9C%E7%B4%A2%E7%9A%84%E8%B7%AF%E5%BE%84%E6%98%AF%EF%BC%9A%3CBR%20%2F%3E%2FHOME%2FTeuser%2Fs32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe-1.0.0%2Ffsl-auto%20%2FHOME%2FTeuser%2Fs32g2%2Ffsl-auto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffsl-auto%20%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffsl-auto%20g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2FPFE%2FFiles%2Ffsl-auto-teuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe-1.0.0%2Fs32g274ardb2%20%2FHOME%2FTEUSER%2Fs32G2%2FFSL-Auto-yocto-bsp%2Fsp%2Fmeta-ALB%2Frecipes-kernel%2Fpfe-1.0.0%2Fs32g274ardb2%20sources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe%2Fs32g274ardb2%20%2Fhome%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsou%20%3CBR%20%2F%3E%20rces%2F%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Emeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2Fs32g274ardb2%20%2Fhome%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe-1.0.0%2Fs32CC%20%2Fhome%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe-1.0.0%2Fs32CC%20%2Fhome%2Fteuser%2Fs32g2%2Ffsl-auto-yoct%2Fpfe%2Fs32CC%20%2FHOME%2FTEUSER%2Fs32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2Fs32CC%20%2FHOME%2FTEUSER%2Fs32G2%2FFSL-AUTO-YOCTO-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe-1.0.0%2Fs32%20%2FHOME%2FTeuser%2Fs32G2%2Fsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe-1.0.0%2Fs32%20%2FHOMEfsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe%2Fs32%20%2FHOME%2FTeuser%20%3CBR%20%2F%3E%20%2Fs32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-recipes-cipes-bsp%2Fsources%2Fm%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Ekernel%2Fpfe%2Ffiles%2Fs32%20%2FHOME%2FTEUSER%2Fs32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe-1.0.0%2Farmv8A%20%2FHOME%2FTEUSER%2Fs32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe-1.0.0%2Farmv8A%20%2FHOME%2FTeuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe%2Ffiles%2Farmv8a%20%2Fhome%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe-1.0.0%2Faarch64%20%2Fhome%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe-1.0.0%2Fsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe%2Faarch64%20%2FHOME%2F%20%3CBR%20%2F%3E%20Teuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe%2Fpfe%2Fpfe-kernel%2Fpfe%2FPFE%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Efiles%2Faarch64%20%2FHOME%2FTEUSER%2Fs32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe-1.0.0%2Fs32G%20%2FHOME%2FTeuser%2Fs32G2%2FFSL-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe-1.0.0%2Fs32G%20%2FHOME%2FTeuser%2Fs32G2%2FFSL-AUTO-YOCTO-bsp%2Fsour%20%3CBR%20%2F%3E%20ces%2Fmeta-alb%2Frecipes-kernelfsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2FPFE%2FFiles%2Fs32G%20%2Fhome%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe-1.0.0%2Fs32G2%20%2Fhome%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe%2Fs32G2%2FFSL-AUTO-YOCTO-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe%2Fs32G2%20%2Fhome%2Fteuser%2Fs32G2%2FFSL-Aocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe%2Ffiles%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe-1.0.0%2Faarch64%20%2Fhome%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2Fpfe-1.0.0%2Faarch64%20%2Fhome%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bkernel%2FPFE%2FPFE%2Faarch64%20%2FHOME%2FTEUSER%2Fs32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kernel%2FPFE%2FFiles%2Faarch64%20%2FHOME%2FTEUSER%2FS32G2%3CBR%20%2F%3E%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3Efsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe-1.0.0%2F%20%2Fhome%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-ALB%2Frecipes-kerneles%2Fmeta-alb%2Frecipes-kerneles%2Fpfe-kerneles%2Fmeta-alb%2Frecipes-kerneles%2Fpfe-kerneles%2Fmeta-alb%2Frecipes-kerneles%2Fpfe-kerneles%2Fmeta-%2Fpfe%2Ffiles%2F%20%2FHOME%2FTEUSER%2Fs32G2%2Ffsl-auto-yocto-bsp%2F%E4%B8%8B%E8%BD%BD%E9%94%99%E8%AF%AF%EF%BC%9Apfe-1.0.0-r0%20do_fetch%EF%BC%9ABitbake%20F%20%3CBR%20%2F%3E%20etcher%20%E9%94%99%E8%AF%AF%EF%BC%9AfetchError%EF%BC%88%E2%80%9C%E6%97%A0%E6%B3%95%E4%BB%8E%E4%BB%BB%E4%BD%95%E6%9D%A5%E6%BA%90%E8%8E%B7%E5%8F%96%20URL%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E'%EF%BC%8Cfile%3A%2F%2F.%2Fs32g_pfe_class.fw')%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%85%E9%9A%9C%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E5%AD%98%E5%82%A8%E5%9C%A8%EF%BC%9A%2FHOME%2Fteuser%2Fs32g2%2Ffsl-auto-yocto-bsp%2Fbuild_s32g274ardb2%2Ftmp%2Fwork%2Fs32g274ardb2-fsl-linux%2Fpfe%2F1.0.0-r0%2Ftemp%2Flog.do_fetch.122939%20%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%BB%BB%E5%8A%A1%EF%BC%88%2FHOME%2FTEUSER%2Fs32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe_1.0.0.bb%3A%20do_FETCH%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E4%B8%BA%20%E2%80%9C1%E2%80%9D%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E4%BB%BB%E5%8A%A1%E6%91%98%E8%A6%81%EF%BC%9A%E5%B0%9D%E8%AF%95%E4%BA%86%202128%20%E4%B8%AA%E4%BB%BB%E5%8A%A1%EF%BC%8C%E5%85%B6%E4%B8%AD%202125%20%E4%B8%AA%E4%B8%8D%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%EF%BC%8C1%20%E4%B8%AA%E4%BB%BB%E5%8A%A1%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2171111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E9%87%91%E8%B4%B5%E5%AE%BE%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetcher%20error%20while%20building%20the%20image%20after%20including%20pfe%20pfe-slave%20in%20local.conf.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243266%22%20target%3D%22_blank%22%3E%40hulk101%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%8D%EF%BC%8C%E6%8F%90%E5%88%B0%E7%9A%84%E6%96%87%E4%BB%B6%E6%98%AF%E6%81%A9%E6%99%BA%E6%B5%A6%E9%85%8D%E7%BD%AE%E7%9A%84PFE%E5%9B%BA%E4%BB%B6%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%85%B6%E4%B8%8B%E8%BD%BD%E5%88%B0%E4%BD%A0%E7%9A%84%E8%B4%A6%E6%88%B7%E4%B8%AD%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1758188868304.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1758188868304.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357509i52BCC0C6D66F472B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1758188868304.png%22%20alt%3D%22chenyin_h_0-1758188868304.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E8%BF%99%E4%B8%8D%E6%98%AF%20BSP38%20%E4%BD%BF%E7%94%A8%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%B8%8B%E8%BD%BD%201.7.1%20PFE%20FW%20%E4%B8%8E%20BSP38%20%E9%85%8D%E5%90%88%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetcher%20error%20while%20building%20the%20image%20after%20including%20pfe%20pfe-slave%20in%20local.conf.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3ENXP_FIRMWARE_LOCAL_DIR%20%E6%9C%AA%E6%B7%BB%E5%8A%A0%E3%80%82%E6%88%91%E6%90%9C%E7%B4%A2%E4%BA%86%22s32g_pfe_class.fw%22%20%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E3%80%82%E6%88%91%E5%BA%94%E8%AF%A5%E8%87%AA%E5%B7%B1%E5%88%9B%E5%BB%BA%E8%BF%99%E4%B8%AA%E6%96%87%E4%BB%B6%E5%90%97%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetcher%20error%20while%20building%20the%20image%20after%20including%20pfe%20pfe-slave%20in%20local.conf.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243266%22%20target%3D%22_blank%22%3E%40hulk101%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%8E%E6%97%A5%E5%BF%97%E6%9D%A5%E7%9C%8B%EF%BC%8CYocto%20%E6%89%BE%E4%B8%8D%E5%88%B0%20PFE%20FW%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E5%B7%B2%E6%A0%B9%E6%8D%AE%20UM%20%E6%B7%BB%E5%8A%A0%E4%BA%86%E5%AE%83%E5%91%A2%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1758180124137.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1758180124137.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357463iCD2FCF493AA76D25%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1758180124137.png%22%20alt%3D%22chenyin_h_0-1758180124137.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetcher%20error%20while%20building%20the%20image%20after%20including%20pfe%20pfe-slave%20in%20local.conf.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%2038.0%20%E7%89%88%E6%9C%AC%E7%94%A8%E4%BA%8E%E6%9E%84%E5%BB%BA%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetcher%20error%20while%20building%20the%20image%20after%20including%20pfe%20pfe-slave%20in%20local.conf.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243266%22%20target%3D%22_blank%22%3E%40hulk101%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%83%BD%E7%9F%A5%E9%81%93%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
