Enable Flex CAN on GoldBox3 board
MohamedAbdelslam
Hi all,
I want to enable Flex CAN on GoldBox3 , on s32g399ardb3 board i was connecting flexcan0 to flexcan1 and the connection was working fine as Enablement guide document.
Is there any similar guide document that provide example for how to enable CAN on GoldBox3 board.
I would appreciate it if there is any guide or instructions that help in this topic as i tried a lot.
Thanx in advance.
chenyin_h
Hello, @MohamedAbdelslam
Thanks for your post.
For using FlexCAN on GoldBOX3, it is the same with the method on S32G-VNP-RDB3, you may reference the chapter "CAN Information" of BSP UM for details.
Chenyin
