Can_43_LLCE driver sample code change CANFD to Classical CAN
TimHu
I download LLCE CAN driver, running LLCE CAN example code ok, and can frame is CANFD in example code currently, I want to change CANFD to classical CAN(CAN2.0),but I can not find any option related about can frame format setting,
please let me know where can I find options related about can frame format setting,thanks.
Daniel-Aguirre
If you want to change that specific flag to FALSE, you need to delete the "CanControllerFdBaudrateConfig" feature inside the specific "CanControllerBaudrateConfig" feature. Image below shows that once deleted, the flag changes to FALSE:
Where it is seen that the "CanControllerFdBaudrateConfig" is not existent, hence the flag is set to FALSE.
Please, let us know.
