BSP44 U-boot pfe firmware not found
cf-technica
I'm using BSP44 Auto Linux BSP. When booting u-boot I cannot get pfe working.
The reason is "PFEng firmware file 'mmc@0:2:s32g_pfe_class.fw' loading failed: -2" error shown on console.
When executing fatls on mmc 0:2, I can see that  s32g_pfe_class.fw is not present in that partition.
=> fatls mmc 0:2
15693832 Image
51422 te_devicetree.dtb
I've tried to flash a bigger .sdcard (100MB) just in case I was flashing a partial image, but it not worked and pfe firmware still does not appear on mmc partition.
During Yocto compilation, I've added the NXP_FIRMWARE_LOCAL_DIR to pfe firmware and DISTRO_FEATURES:append = " pfe" and DISTRO_FEATURES:append = " pfe-master" in local.conf.
After yocto compilation, I can see that pfe firmware is installed on the Linux partition at /usr/lib/firmware/ but it's not present on the boot partition needed by u-boot.
Is this a bug on BSP44, should I change something in my yocto configuration in order to add pfe_firmware in the boot partition? It worked with BSP40, but not anymore.
Tags (4)
chenyin_h
Hello, @cf-technica
Thanks for your reply.
I suggest trying the following command(bitbake fsl-image-auto -c cleansstate), and then re-build the image
Chenyin
chenyin_h
Hello, @cf-technica
OK, so that both PFE and hse need to be enabled in your build, right? any other functions need to be added, would you mind share your conf/local.conf contents? I would check it firstly and try additional check from my side.
Sorry for your inconvenience.
Chenyin
chenyin_h
Hello, @cf-technica
Chenyin
chenyin_h
Hello, @cf-technica
Thanks for your post.
I have tested on my end with the following modification via conf/local.conf
NXP_FIRMWARE_LOCAL_DIR = "PATH_TO_THE_PFE_FW"
And the PFE FW is loaded to the right partition
=> fatls mmc 0:2
15491080 Image
61479 s32g399a-rdb3.dtb
45724 s32g_pfe_class.fw
Would you mind double checking on it? I suggest firstly changing the settings as what I have provided, and then cleaning your building, at last, rebuilding the yocto with another test.
Chenyin
cf-technica
Sorry for the late response.
I've added theses variables on my yocto project compilation local.conf:
NXP_FIRMWARE_LOCAL_DIR = " /yocto/sources/meta-te-myS32g/recipes-kernel/pfe/files"
Where NXP_FIMRWARE_LOCAL_DIR points to the full path where the .fw files are located.
Also, taking a look at the yocto environment I can see that the firmware file is added.
"SDCARDIMAGE_BOOT_EXTRA_FILES": " pfe-firmware:s32g_pfe_class.fw"
"SDCARDIMAGE_EXTRA2_FILE": "s32g_pfe_class.fw"
But I still cannot see it on the flashed .sdcard mmc0:2 partition.
There's a yocto warning when I compile:
WARNING: image-te-devel-1.0-r0 do_image_sdcard: SDCARDIMAGE_EXTRA1_OFFSET is undefined. To use the 'sdcard' image it needs to be defined as byte offset.
Could this OFFSET explain the issue? How should I calculate this value?
Tags (4)
cf-technica
I tried the proposed solution "bitbake fsl-image-auto -c cleansstate and bitbake fsl-image-auto"
Also added
To local.conf but now HSE receipt is failing. With the following error:
ERROR: /yocto/sources/meta-alb/meta-alb-bsp/recipes-bsp/hse/hse-firmware.bb: hse-firmware: LIC_FILES_CHKSUM contains an invalid URL: /yocto/sources/meta-te-s32g/recipes-kernel/pfe/files//HSE_FW_S32G2XX_0_2_64_0/license.rtf;md5=bafc2fc12f6ba76334b95f6ea4844b01
Seems that hse recipe is using also NXP_FIRMWARE_LOCAL_DIR as source directory and adding the pfe path is messing things.
Also I've tried to add DISTRO_FEATURES:remove = " hse" in local.conf but it's not solving the problem and error still appears.
%3CLINGO-SUB%20id%3D%22lingo-sub-2159883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBSP44%20U-boot%20pfe%20firmware%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3EI'm%20using%20BSP44%20Auto%20Linux%20BSP.%20When%20booting%20u-boot%20I%20cannot%20get%20pfe%20working.%26nbsp%3B%3C%2FP%3E%3CP%3EThe%20reason%20is%20%22PFEng%20firmware%20file%20'mmc%400%3A2%3As32g_pfe_class.fw'%20loading%20failed%3A%20-2%22%20error%20shown%20on%20console.%26nbsp%3B%3C%2FP%3E%3CP%3EWhen%20executing%20fatls%20on%20mmc%200%3A2%2C%20I%20can%20see%20that%26nbsp%3B%26nbsp%3Bs32g_pfe_class.fw%20is%20not%20present%20in%20that%20partition.%26nbsp%3B%3C%2FP%3E%3CP%3E%3D%26gt%3B%20fatls%20mmc%200%3A2%3CBR%20%2F%3E15693832%20Image%3CBR%20%2F%3E51422%20te_devicetree.dtb%3C%2FP%3E%3CP%3EI've%20tried%20to%20flash%20a%20bigger%20.sdcard%20(100MB)%20just%20in%20case%20I%20was%20flashing%20a%20partial%20image%2C%20but%20it%20not%20worked%20and%20pfe%20firmware%20still%20does%20not%20appear%20on%20mmc%20partition.%3C%2FP%3E%3CP%3EDuring%20Yocto%20compilation%2C%20I've%20added%20the%26nbsp%3B%3CSTRONG%3ENXP_FIRMWARE_LOCAL_DIR%3C%2FSTRONG%3E%20to%20pfe%20firmware%20and%26nbsp%3B%3CSTRONG%3EDISTRO_FEATURES%3Aappend%20%3D%20%22%20pfe%22%20and%20DISTRO_FEATURES%3Aappend%20%3D%20%22%20pfe-master%22%3C%2FSTRONG%3E%20in%20local.conf.%3C%2FP%3E%3CP%3EAfter%20yocto%20compilation%2C%20I%20can%20see%20that%20pfe%20firmware%20is%20installed%20on%20the%20Linux%20partition%20at%20%2Fusr%2Flib%2Ffirmware%2F%20but%20it's%20not%20present%20on%20the%20boot%20partition%20needed%20by%20u-boot.%26nbsp%3B%3C%2FP%3E%3CP%3EIs%20this%20a%20bug%20on%20BSP44%2C%20should%20I%20change%20something%20in%20my%20yocto%20configuration%20in%20order%20to%20add%20pfe_firmware%20in%20the%20boot%20partition%3F%20It%20worked%20with%20BSP40%2C%20but%20not%20anymore.%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BSP44%20U-boot%20pfe%20firmware%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251219%22%20target%3D%22_blank%22%3E%40cf-technica%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EOK%2C%20so%20that%20both%20PFE%20and%20hse%20need%20to%20be%20enabled%20in%20your%20build%2C%20right%3F%20any%20other%20functions%20need%20to%20be%20added%2C%20would%20you%20mind%20share%20your%20conf%2Flocal.conf%20contents%3F%20I%20would%20check%20it%20firstly%20and%20try%20additional%20check%20from%20my%20side.%3C%2FP%3E%0A%3CP%3ESorry%20for%20your%20inconvenience.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BSP44%20U-boot%20pfe%20firmware%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3EI%20tried%20the%20proposed%20solution%20%22bitbake%20fsl-image-auto%20-c%20cleansstate%20and%26nbsp%3Bbitbake%20fsl-image-auto%22%3C%2FP%3E%3CP%3EAlso%20added%26nbsp%3B%3CBR%20%2F%3EDISTRO_FEATURES%3Aappend%20%3D%20%22%20pfe%22%3CBR%20%2F%3ENXP_FIRMWARE_LOCAL_DIR%20%3D%20%22%20%2Fyocto%2Fsources%2Fmeta-te-myS32g%2Frecipes-kernel%2Fpfe%2Ffiles%22%3C%2FP%3E%3CP%3ETo%20local.conf%20but%20now%20HSE%20receipt%20is%20failing.%20With%20the%20following%20error%3A%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EERROR%3A%20%2Fyocto%2Fsources%2Fmeta-alb%2Fmeta-alb-bsp%2Frecipes-bsp%2Fhse%2Fhse-firmware.bb%3A%20hse-firmware%3A%20LIC_FILES_CHKSUM%20contains%20an%20invalid%20URL%3A%20%2Fyocto%2Fsources%2Fmeta-te-s32g%2Frecipes-kernel%2Fpfe%2Ffiles%2F%2FHSE_FW_S32G2XX_0_2_64_0%2Flicense.rtf%3Bmd5%3Dbafc2fc12f6ba76334b95f6ea4844b01%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESeems%20that%20hse%20recipe%20is%20using%20also%26nbsp%3BNXP_FIRMWARE_LOCAL_DIR%20as%20source%20directory%20and%20adding%20the%20pfe%20path%20is%20messing%20things.%3C%2FP%3E%3CP%3EAlso%20I've%20tried%20to%20add%26nbsp%3BDISTRO_FEATURES%3Aremove%20%3D%20%22%20hse%22%20in%20local.conf%20but%20it's%20not%20solving%20the%20problem%20and%20error%20still%20appears.%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BSP44%20U-boot%20pfe%20firmware%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251219%22%20target%3D%22_blank%22%3E%40cf-technica%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EI%20suggest%20trying%20the%20following%20command%EF%BC%88bitbake%20fsl-image-auto%20-c%20cleansstate%EF%BC%89%2C%20and%20then%20re-build%20the%20image%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BSP44%20U-boot%20pfe%20firmware%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3ESorry%20for%20the%20late%20response.%26nbsp%3B%3C%2FP%3E%3CP%3EI've%20added%20theses%20variables%20on%20my%20yocto%20project%20compilation%20local.conf%3A%26nbsp%3B%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3EDISTRO_FEATURES%3Aappend%20%3D%20%22%20pfe%22%3CBR%20%2F%3ENXP_FIRMWARE_LOCAL_DIR%20%3D%20%22%20%2Fyocto%2Fsources%2Fmeta-te-myS32g%2Frecipes-kernel%2Fpfe%2Ffiles%22%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EWhere%20NXP_FIMRWARE_LOCAL_DIR%20points%20to%20the%20full%20path%20where%20the%20.fw%20files%20are%20located.%3CBR%20%2F%3E%3CBR%20%2F%3EAlso%2C%20taking%20a%20look%20at%20the%20yocto%20environment%20I%20can%20see%20that%20the%20firmware%20file%20is%20added.%26nbsp%3B%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%22SDCARDIMAGE_BOOT_EXTRA_FILES%22%3A%20%22%20pfe-firmware%3As32g_pfe_class.fw%22%3CBR%20%2F%3E%22SDCARDIMAGE_EXTRA2_FILE%22%3A%20%22s32g_pfe_class.fw%22%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EBut%20I%20still%20cannot%20see%20it%20on%20the%20flashed%20.sdcard%20mmc0%3A2%20partition.%26nbsp%3B%3C%2FP%3E%3CP%3EThere's%20a%20yocto%20warning%20when%20I%20compile%3A%26nbsp%3B%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3EWARNING%3A%20image-te-devel-1.0-r0%20do_image_sdcard%3A%20SDCARDIMAGE_EXTRA1_OFFSET%20is%20undefined.%20To%20use%20the%20'sdcard'%20image%20it%20needs%20to%20be%20defined%20as%20byte%20offset.%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3ECould%20this%20OFFSET%20explain%20the%20issue%3F%20How%20should%20I%20calculate%20this%20value%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2160503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BSP44%20U-boot%20pfe%20firmware%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2160503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251219%22%20target%3D%22_blank%22%3E%40cf-technica%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3EI%20have%20tested%20on%20my%20end%20with%20the%20following%20modification%20via%20conf%2Flocal.conf%3C%2FP%3E%0A%3CP%3EDISTRO_FEATURES%3Aappend%20%3D%20%22%20pfe%22%3CBR%20%2F%3ENXP_FIRMWARE_LOCAL_DIR%20%3D%20%22PATH_TO_THE_PFE_FW%22%3C%2FP%3E%0A%3CP%3EAnd%20the%20PFE%20FW%20is%20loaded%20to%20the%20right%20partition%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3D%26gt%3B%20fatls%20mmc%200%3A2%3CBR%20%2F%3E15491080%20Image%3CBR%20%2F%3E61479%20s32g399a-rdb3.dtb%3CBR%20%2F%3E45724%20s32g_pfe_class.fw%3C%2FP%3E%0A%3CP%3EWould%20you%20mind%20double%20checking%20on%20it%3F%20I%20suggest%20firstly%20changing%20the%20settings%20as%20what%20I%20have%20provided%2C%20and%20then%20cleaning%20your%20building%2C%20at%20last%2C%20rebuilding%20the%20yocto%20with%20another%20test.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
