0001-ipc-multi-instances.patch from AN13750 ("Enabling Multicore Application on S32G2 .pdf")
ソリューションへジャンプ
6,867件の閲覧回数
SSyb
Hi all,
I am refering to NXP Application Note AN13750 / Enabling Multicore Application on S32G2.pdf.
This documents mentions several patch files to be applied to standard repos sources, one of them is: 0001-ipc-multi-instances.patch.
I may be blind, but I can not find this file, neither in one of the repos cloned in the course of following the application note, nor as an attachment to the PDF.
Any ideas where to find these patches ?
best regards, Stefan
タグ(1)
6,852件の閲覧回数
Daniel-Aguirre
The patch and the projects used in the AN13750 is available under the same section you download it from the S32G2 product page (link: S32G2 Safe and Secure Vehicle Network Processor | NXP Semiconductors) with the name "AN13750SW". You can filter by "Application Note Software" to make it easier to find.
Please, let us know.
2 返答(返信)
6,853件の閲覧回数
Daniel-Aguirre
6,826件の閲覧回数
SSyb
that's where I dod not look - Thanks !
