what's the difference between can_pal and flexcan?
1,036 次查看
fedora
Hi team:
    There are can_pal and flexcan modules in PE, what's the difference between them?
How to choose them?
     Thanks!
标记 (2)
1,022 次查看
Julián_AragónM
Hi @fedora,
PAL refers to the Peripheral Abstraction Layer, it can contain a family of peripherals, and it uses generic API on multiple platforms for a better portability, while PD (or examples without the "PAL" suffix), refers to Peripheral Drivers, which are specific IP dedicated low-level drivers, for high efficiency.
You can refer to this community post, where it is explained in a little bit more detail: S32K144 Driver vs PAL? - NXP Community. It is also described in the SDK documentation.
Julián
1,023 次查看
Julián_AragónM
Hi @fedora,
Julián
963 次查看
fedora
Ok, I have got it !  Thanks, Julián
