pdb triggers adc in s32k144
已解决
跳至解决方案
2,140 次查看
zhangchun
hello
Ftm0 in s32k144_ PWM triggers PDB0 PDB1 through TRGMUX and pre triggers adc0 adc1. It is expected that by closing the trigger in the adc1 interrupt and reading the conversion results of ADC0 and ADC1, the trigger will be opened in the PDB interrupt, so that the PDB pre triggers ADC continuously in a loop.
Now, there have been PDB error interrupts throughout this process, and ADC interrupts have not been generated. Please help me take a look at the issue
Thanks!
标签 (1)
1 解答
2,107 次查看
PetrS
you need to read all ADC results that are triggered/converted. I see 3 channels are triggered, but you read just 2 result registers. In this case lock of pretrigger can happen and error generated.
BR, Petr
在原帖中查看解决方案
4 回复数
2,108 次查看
PetrS
BR, Petr
2,102 次查看
zhangchun
hello
Thank you very much for your reply,
After reading the three ADC channels, it can work normally,
Now I want a PWM cycle to trigger the ADC twice for current sampling. Can this solution be implemented?
2,087 次查看
PetrS
yes, that is possible. The PDB trigger source selection is implemented through the TRGMUX module, so you can select trigger signal form PWM module (FTM). And then you can set pretrigger delays in PDB to sample channel twice.
BR, Petr
2,082 次查看
zhangchun
I may not quite understand what you mean. The implementation failed. Can you provide me with an example?
