enet ping missing from sdk
1,783 次查看
janijärvenpää
RTM 3.0.2 release note lists enet ping as example.
I installed the SDK but i can't find this example at all?
1,706 次查看
razva_tilimpea
Did you installed RTM 3.0.2 on top of RTM 3.0.0?
Razvan
1,706 次查看
janijärvenpää
Yes i did.
1,706 次查看
razva_tilimpea
Hi Jani,
I have check it again and you are right there is a wrong name for enet example. The right example name for enet is enet_loopback_s32k148. The problem is that this example doesn't provide support for ping.
If you want to see how to use ping please check lwip_s32k148 example.
Razvan
