Using SD-ADC in S32R274 EVB
2,776 次查看
samco1919
I am new to NXP products and doing my first steps using the S32R274 EVB.
I am trying to implement a fast adc sampler for signal processing application. From the datasheet, the SAR-ADC maximum sampling frequency is 1MSps and the SD-ADC is 10MSps. For my application I would prefer the higher sampling frequency.
While mentioned few times in the datasheet and reference manual, I could not find any example or technical information on how to use the SD-ADC. The SAR-ADC is very straight forward with it's ready to use standalone component/ as part of the ADC-PAL. I also could not find an implementation in the RSDK.
If someone can please guide me toward an example or tutorial it would be great.
Thank you
标签 (2)
标记 (4)
1 回复
2,640 次查看
Hong_Tang
I met the same problem, so could you please tell me how you figured it out? Thank you.
