S32k116 compiles the size problem on keil
3,205件の閲覧回数
luo_jh
I applied the 2.9.2 version of sdk on keil, compiled and found that the data sent and received by can be big endian, which is different from the result of compiling on s32ds. How can I solve it?
The attachment is a screenshot of the code I followed.
タグ(5)
3,066件の閲覧回数
victorjimenez
Sorry for the late reply. Are you still facing this issue? If so, could you please share more information about it? For example, how are you confirming that the send and receive data through can is big-endian while working with Keil? Are you using any of the examples that we provide within the SDK? If so, how did you import this example to Keil?
Victor
