I have the same board, and just started playing with it. I use Linux btw.
There is a problem with onboard interface, debugging session fails
PEmicro GDB Launch Failure : Unable to auto-detect debug hardware. Please specify on the command-line. If running from Eclipse, check the launch Debug Configuration settings. Halting.
lsusb shows ID 1357:0503 P&E Microcomputer Systems USB-ML-12 HCS08/HCS12 Multilink
is it compatible with PEMicro GDB debug configuration?
