S32K148 project expert processor display S32K144 SDK
建宽高
HI
when i create s32k148 project,but   expert processor display S32K144 SDK
martin_kovar
I am not sure, what is your question. Could you please clarify, which version of SDK you used for the project?
From my point of view, showed version does not matter, because some components are shared between microcontrollers. So, if you chose project for S32K148 in start wizard, it will work correct.
Martin
